Need to create a section that combines a full section and a half section for a concentrically assembled assembly. Please refer "section.png" for detail info.
Thanks in Advance
Prakash
The reason you can't do this is because it is not standard sectioning. Or at least not like anything I've ever seen. How would the section be referenced in a view orthogonal to the section view? You can't have a combination of an offset section and a planar section in this fashion. Why not just make an offset section with the 1/4 "pie slice" cut out?
See the attachment. I was able to achieve this using 2 sections in a view.
Hi @Prakash_P,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Anurag
