drawing right click menu
creed-4
In Creo 3.0 drawing mode, my right click menu only flashes when I try to access.  It flashes too quickly & will not allow me to select any options.  Is there any way to fix the issue without closing out completely?  What causes this to happen?
Thanks in advance
tgriffin
(To:creed-4)
It might be getting hidden behind your current window if you have that window locked in front.  Press ctrl+alt+esc in your main creo window and see if that helps.
creed-4
(To:tgriffin)
I use 2 monitors and had the drawings on one monitor & the assembly model on the other. I will try ctrl+alt+esc next time it happens.
