Can anybody know how to manage this problem ,as i just updated creo 2 from pro e wildfire ,it happened in all drawing sheets .
I dont have an idea of changing this decimal places.
Manish
Manish,
If you are working with Creo 2.0 M090 or later, you may try updating the drawing by setting a drawing option update_drawing with value as 2140864.
1. Open drawing.
2. File > Prepare > Drawing Properties > Change for Detail options > Add option update_drawing and value as 2140864
3. Review > Update Sheets > Save
Mahesh.
Please check it already set as default in my sketcher ,please suggest some other options.
Manish
No its not working,i think i have to re dimension it ,cause when i re dimension ,its in shape.
Manish
Manish,
I have seen your problem before so this might work. Right mouse click on the dim and bring up the properties and make sure that the rounded dimension value is clicked or checked.
Rick
Rick,
Yes by clicking rounded dimension value its working,but is there in method of doing in one stroke.
Itself it is also a great help.
Thanks Rick.
Manish
In my config.pro has:
default_dec_places 6
default_ang_dec_places 2
but, when I want to work with Drawings, I add in the Drawings folder a current_session.pro with:
default_dec_places 2
default_ang_dec_places 1
and in the Options I will import this file to chage the defaults values of the config.pro.
Manish,
1. Open drawing.
Mahesh.
Mahesh, maybe you can explain a little more about this drawing option?
What has changed in M090 that required this? What previous version drawings does it affect? What features does it affect?... etc.
Hello Mahesh,
Please explain. What does it change? And why M090 or later?
~J
2140864 is SPR number which was submitted to report this issue and has been resolved in Creo 2.0 M090. This SPR number can be used to update the drawings to correct the decimal places. Once update_drawing 2140864 will apply to a drawing, drawing option will correct the issue and will not available in that drawing detail option list.
Mahesh,
Is there a compilation of all the SPR numbers and a description of the problem each one solves?
Thanks!
There is not. You can test if an issue you have is fixed by such a thing by using 'update_drawing all' (followed by regeneration of the relevant items). If it is, you can inspect the drawing to ensure that any changes are as desired and proceed, or if you need to only fix the one bug (say, update_drawing all also fixes something that moves around your carefully placed detailing), then you can file an SPR to have the specific update identified.
