I currently use CREO 2.0 and was wondering if hole transfer from one part to a mating part is any easier in the new CREO 4.0? If you have a lot of holes to transfer from one plate to a mating plate, it is a real chore!
David
have you found anything regarding this matter?
I was looking for something simillar
You can do this in an assembly either as an assembly feature that is or is not shown in the .prt file (depending on the options you select or you can activate the part (in the assy) you want to transfer the holes to and use the existing holes as references, you can later remove those reference if you don't want them.
