so since creo 3.0 every time i use (fraction dimensions) either the diameter dimension (by double clicking on a hole in the drawing) or the arc dimension (again in the drawing) the default denominator is set at 4.
I have logged a case with ptc but now even after 2 new version releases this is still an issue.
this is causing many issues with our entire companies production drawings.
config settings :
dim_fraction_format aisc
create_fraction_dim yes
dim_fraction_denominator 16
grrrrrr.....
if anyone has this same issue i would love to hear from you.
if you have found a fix, or if you can identify something that maybe I have done to cause this, I would love to hear from you.
thank you,
J-G
What was the reply from customer support?
they remote controlled into my computer and tried to fix it but they couldn't, so they filed a case.
J-G,
I see that SPR 2247672 was submitted on your behalf. The SPR was opened with Medium severity. If this has since increased, I recommend that you contact the TSE assigned to your case and ask that they raise the severity.
