mapkey set up
bxu
3-Visitor
3-Visitor
mapkey set up
mapkey was set up on assembly status, it does not work in part, how to fix it? thanks
Chris3
20-Turquoise
(To:bxu)
Either you are going to have to re-record in part mode or you are going to need to post the mapkey, a description of what you are trying to do with it and the version of Pro/E or Creo you are using.
