table in drawing
ahuderek
table in drawing
I have a little problem with table in Creo 2. I already create my ow table with commands like:
&scale
&todays_date
&PTC_common_name
&model_name
etc
I saved this table and when I want to use it again something wrong is happening like in picture in annex.
Also i woluld like change scale format to 1:4 not 0.25
Remove the :9
why it is there someone else will need to explain
change to ratio scaling:
add/change values in your .dtl file:
view_scale_denominator 100
view_scale_format RATIO_COLON
Adam,
number 9 following collon character is Session ID. It is dynamic ID assigned to the assembly and its components during assembly opening. See the picture of my test assembly.
1st component has Session ID 0
2nd -> 2
3rd -> 4
4th -> 6
Martin Hanak
