I am using Creo direct modeling 19.0 and have a model of the thermoform tray with several cavities. When I try to add a blend to any one of the edges, the model disappears. Sometimes, in the structure tree, several copies of the model show up, but the screen is blank. I have tried using constant and variable radii. I cannot using extrude cut with the corner fillets in the 2D, because that yields a cone, because the cavity walls have a draft angle. Also, almost every modification I make on the model turns it into a face part.
Sharon,
I'm not sure how to advise without seeing the object. Can you please provide a few screenshot of the model or the file itself?
Sorry, but I cannot share a photo, since the model is proprietary. But consider it something similar to a seedling tray for plants. The depressions have sharp edges that need blends.
I guess HP is under Support.
If so, you can log a Case with PTC Support and mark it as NDA - then PTC will initiate a very strict process
which guarantees that your data is kept proprietary.
If you are in assembly mode try config option - dim_inactive_components - (ref Creo 3.0 )
Yes more info will help, are you 3D or 2D?
Good hunting,
Sharon is using Creo Elements Direct, NOT CREO.
Sometimes it helps to export such a part as IGS and then import it again with high repair level.
What is the resolution of this part?
Is the radius eventually bigger than the wall thickness?
