mass property
cspinelli
mass property
hello,
is it possible to visualize mass property with Creo View Lite?
thanks
Hello Christian,
Where do you want the mass property to be displayed, will it be on CAD or Drawing ?
cspinelli
(To:Anand)
if i open Creo View Lite, i want to see mass property from cad model
Dear Christian,
As per the PTC article CS176958, In Creo view it's not possible to retrieve the mass properties
Athmanand
magnus.salomons
(To:Anand)
It is possible but you will have to judge how reliable it is. We haven't seen any major differences. See this thread in what versions of Creo View it's available Volume measurement in Creo View
thanks all i found in another article that Creo View M031 has mass property tab.
thanks again
