Disable PDMLink 10.1 from carrying forward old iteration's image
DonSenchuk
7-Bedrock
I'm looking for a way to stop Windchill PDMLink from carrying forward the Creo View images from previous iterations.
Currently, if a publish job fails the system will pull forward the image from the previous iteration. As you can imagine, this causes a problem when people try to review the drawings from Creo View and get a half-completed mess, yet when the file is opened in Creo Parametric everything is completed properly.
Any ideas?
Hey Don,
I've got this in my site.xconf file and I do not get the old iteration image.
<Property name="publish.copyrepresentationsforward" overridable="true"
targetFile="codebase/wvs.properties"
value="false"/>
I think this is it as I have had this since 10.0 and am now on 10.2, but someone else set that up for me back then and I have just carried it forward each version.
Hey Don,
value="false"/>
Thanks Brian. I'll give it a test and see how it goes.
