Hello
Is it possible to modify and save a material file. MTL outside Simulate.
Is - it a program that is able to do.
Kind regards.
Denis.
http://www.totalmateria.com/page.aspx?ID=Home&LN=FR
I know of no other application, but Creo. You do not necessarily need Simulate mode, Creo Parametric uses the same materials and allows to edit them.
The files are simply ascii text, so a text Editor may also be an option, if you just need to modify some values.
Hello Günter,
Thanks for your reply.
It would be to be able to create files with the chart outside Creo.
But good if there is no program I would do them in Creo.
Kind regards.
Denis
