I made a horizontal cut drawing from a CAD model, but Creo always highlights the original 3D model and this makes my computer very slow. How can I turn off this annoying function?
Thanks in advance!
David
In FILE - OPTIONS -SELECTION try unchecking the enable preselection highlighting.
This changes the way Creo does selection, so it may not be acceptable.
Hi Williams!
Thank you for your answer, but it didn't solve the problem unfortunately.
Can you add a screen shot of what it is doing?
I'm sorry, but I cannot add screenshot because it's my company's secret...
You'll need to provide more specifics about what you are doing.
Is the "horizontal cut" a cross section? Or did you actually cut the model?
Is the model that is highlighting an imported model?
Does this happen on other drawings or is it just this one?
I made a .drw drawing file from an assembly (.asm) file by define a horizontal plane and make a cross section. And when I'm working on the drawing, which is 2D of course, Creo wants to highlight 3D elements, which are invisible normally.
So I added an arbitrary part to an assy at an odd angle. On a drawing view, I am adding a leader attached note, looks like it highlights surfaces that are on the wrong side of the cut. If that is what you are referring to, I don't think there is a way to turn it off.
Preselection highlight works so it doesn't show when you move the mouse over but it does still select and hightlight when you try to select an attachment point.
The worst I've seen like this is imported surface models tend to show and highlight everything.
Maybe you could replicate it with simple non-proprietary parts that can be shared?
