Vericut 7.1.5 embedded, stop function while verify, where did it go?
snguyen
Good afternoon,
We just switched to Creo 2.0 this week and we are noticing that when
we are using Vericut that is built inside of Creo that the option to stop
the verify at tool change or at errors is not nowhere to be found. It use to
be with the Fast Feed dialog box in Creo Elements.
Thanks in advance.
Son Nguyen
108 w. 2nd Street
Assaria, KS. 67416
(785) 667-7763 ext. 3477
Thank you...
