I have installed the ptc creo parametric 3.0 and vericut 7.4.1.
When I try to simulate material removal at vericut, ptc says that the application vericut_dll is not available or is not supported in this platform.
Why this happen? what i am doing wrong? HELP please
Juan,
One of the known possible reason for this message is Vericut installation. If it is not installed, Vericut_dll message will appear.
With Creo 3.0, reinstall application and page to application to be install select Customize > Creo Parametric > And check Vericut to install.
Check information available at:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS28961
Hello Juan,
have you been able to solve the issue with the help of Mahesh and Martin?
If so, please take the time to mark one post as Correct Answer. This will signal to community that the issue is resolved.
Gunter
No, I can´t see the post. I only have an studient license.
You are currently setup with a Basic PTC.com Account that does not provide access to this area of eSupport. This means that you may have an active PTC Global Support agreement however you have not yet Upgraded your Account to reflect your Support entitlements. To access this area please
