creo flow
aburdi-2
creo flow
I have a serious problem with Creo Flow (6.0.2.0.).
I can set up a simulation, run it and review the results but as soon as I close Creo (after saving both Creo Flow project and the main assembly) I get an error while trying to open Creo Flow project again.
Clicking on "Open project" from Creo Flow UI gives the following error:
"Error at line 1 in file xxxxxxxxxx (xxxxxxx are the name of the main assembly file).spro. Unsupported main element domain".
Anyone knows how to solve it?
Thanks.
0 REPLIES 0
