Background in a table
rboneti
Hi Everybody!
I need to put a graphic (image) on the my table's entry background. Can I do it using the styler?
Hi Robson,
This requires a fairly complex solution if it can be done on a per-table basis. Take a look at this article to see if it gives you enough ideas to get it working.
https://www.ptc.com/appserver/cs/view/solution.jsp?n=147736
This talks about using background images on page sets, not per-table or per-cell. It might not help you with what you want. If you can't get it working it would be best to file a support case so you can discuss it in more detail. If you file a case, plan on providing your doctype, a test document and the graphic image you want to use as a background. It will also be helpful to know if you are using FOSI composition or APP composition. This article will help you understand capturing an appsave:
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS146968
Here is a link for filing a technical support case:
https://www.ptc.com/appserver/cs/case/case_logger.jsp
Jerry Tippie
Thank you Jerry!!
I really liked your response! I'm going to try this solution! Soon I'll tell you if it works.
