Context Rules turning on/off
pzorrilla
Hello experts!!
I was wondering... there's a command in ACL which allows me to
automatically turn off the Context Rules Checking in Arbortext?
I really appreciate your response.
Regards.
Paulette Zorrilla
here's a good trick to know:
from the command line:
response(menu_cmd("Tools.Context Rules"))
This will display the command or alias that a menu item executes. For more
details, look up "menu_cmd" in Help.
Note: There are a few menu items in 6.0 that are "hidden" by some tricks
PTC introduced behind the scenes. Edit>Delete Markup being one of them.
Can't remember the trick to get around that right off the bat ...
On Tue, Jun 25, 2013 at 1:39 PM, paulette zorrilla <
paulette.zorrilla@oracle.com> wrote:
> Hello experts!!
> Regards.
> Paulette Zorrilla
Ah, it's:
response(menu_cmd("Edit.&Delete"))
But I don't know how you would know what variable name they used in order
to get around those menu items.
Paul! Thank you so much, as always you've help me a lot 😃 I will investigate now how can I execute the command received 😄
Regards.
Paulette Zorrilla
set context=off
Is there a way to "force" the user to run context checker before closing a document?
Have a look at the ACL command "doc_incomplete()". We have an ad-hoc document management system, and just check that prior to checkin, but I suppose you could do the same on document close.
I will note/warn, however, that occasionally this does produce false-positives, so it might also be a good idea to check if the document is saved first, since that typically corrects things, especially when it comes to caret location.
- keith
