How to combine files into one?
akamaruzzaman
I want to combine my files into one so how do I do that? For example I'm making an epm and I've created seperated files for each sections of the epm so I want to combine them into one.
Could you describe what emp files are?
rdiaz
(To:akamaruzzaman)
Anisah,
What you're talking about sounds like a DITAMap or other such 'container' document.
Depending on what doctypes you are using for the electronic parts, there should be a map document for them.
If not, one would need to be created.
Please let us know if you have more questions on this issue, or if you're all set.
Thanks!
Anisah,
   Do you have further questions?
If you resolved this issue, how did you do so?
