How to export BOM report from Windchill to use in Arbortext IsoDraw
aadal
What is the easiest method to export a BOM reports to use in Arbortext IsoDraw?
IsoDraw accepts xml files for BOM creation in specific format, and I would like to export the necessary xml file from Windchill.
Thanks in advance.
Kind Regards,
Andaç ADAL
Marco_Tosin
(To:aadal)
Starting from Windchill 10 you can export a BOM in XML format, from the Structure tab.
Marco
Marco_Tosin
(To:aadal)
Marco
Hello Marco,
Thank you for your reply. The structure of XML files varies. The output format of Structure tab and Input format of IsoDraw are different.
    For instance;
    From the structure tab, I get an XML report like this:
<SearchResults>
    <TableHeader>
          <ColumnName>File Name</ColumnName>
          <ColumnName>Number</ColumnName>
          <ColumnName>Version</ColumnName>
    </TableHeader>
    <Object>
          <Attribute>kry_fren_piston_grubu.asm</Attribute>
          <Attribute>3ab</Attribute>
          <Attribute>B.4</Attribute>
    </Object>
    <Object>....................
    IsoDraw accepts XML reports like this:
<partsList xmlns="http://www.ptc.com/SIS/2010" version="1.0">
    <cadModel>
          <item calloutValue="KRY_FREN_PISTON_GRUBU">
              <occurrence>
                    <instance isoId="kry_fren_piston_grubu.asm"/>
              </occurrence>
          </item>
          <item..........................
So I need to convert XML files that can cause mistakes.
Do you know any best practices for this issue. Can I import XML files -more- directly?
Marco_Tosin
(To:aadal)
I'm sorry but I can't give you any advice.
Marco
aadal
(To:aadal)
I want to share what I can do for converting BOM reports to use in IsoDraw.
I appreciate who helps us to go further for a more stable solution.
I created an executable JAR file. In this JAR I run a class that uses Saxon library methods.
I write an xslt file to make translations and saved it on file system. I also saved the Windchill Structure report XML file to my file system.
In the code, I process the input file by the xslt file with Saxon library methods.
I put the output file to my filesystem, then I import converted XML file into IsoDraw.
That's what I did so far.
It is good to share. Thanks for reading.
Kind regards,
Andaç
SN_10124887
(To:aadal)
Hello aadal,
Could you please help me with the API to download Product structure as XML in Windhcill?
Srivalli.
