Isodraw Macro ignores the leading zeroes
sk-3
Hi Gang,
I wrote a macro for giving the ICN numbers in the illustrations. It will ask the user some specific inputs. There is a place where it will ask for the starting and ending value numbers. User would give the starting number as 00001 and ending as 0010 (for example). After running the macro when we see the file name and the ICN number in the file, zeroes in front of the value are ignored and it is displayed as 1 and 10. Why Isodraw ignores the zeroes?.
thendricks
3-Visitor
(To:sk-3)
Looks like there may be some other errors in your macro (Run Macro?) so I parsed out the basics to get you what you needed.
Macro ICN
  Define stval as String
  Define endval as String
  Define partno as String
  Define ata as String
  Define stng as String
  Define base as String
  Define base1 as String
  Define base2 as String
  Define base3 as String
  Define base4 as String
  Define pathI  as String
  Define extI  as String
  Define fname as String
  Define cgmname as String
  Define size as Integer
  stval =get integer "Starting Number"
  endval=get integer "Ending Number"
  partno=get String "Part No."
  ata =get String "ATA"
    while (stval <= endval)
    stng = stval
    base1= "ICN-"
      base2="-A-"
      base3="-X-B-4050G-"
      base4="-A-001-1"
      while (len(stng)<5)
        stng = '0' + stng
      end while
      base =base1+partno+base2+ata+base3+stng+base4
      message base
      stval=stval+1
   end while
End Macro
10 REPLIES 10
thendricks
3-Visitor
(To:sk-3)
My guess is that the variables you are using for the ICN values are declared as numbers. What you are attempting to capture however, is not a number. Try declaring your values as strings instead.
Hi Trevor,
Thanks for the reply. Below is my code. I have to declare the variables as integers otherwise the values will not get incremented. Any help is appreciated.
Macro Something
define stval as integer
define endval as integer
stval=get integer "Starting Number"
while(stval>=endval)
Create text "some point"
stval=stval+1
end while
end macro
thendricks
3-Visitor
(To:sk-3)
My suggestion then is to treat the field as an integer as you have. Before outputting it however you'll want to check the character length of the integer and then prefix the necessary number of zeros. You can then output that value while maintaining your integer variable for incrementing.
thendricks
3-Visitor
(To:sk-3)
Any luck?
I tried the following two ways...
1) Macro Something
          stval=get string "Starting Number"
          endval=get string "Ending Number"
          stval=stval+1
end while
end macro
I got output as -0001-A01 and the next number as -00011-A01. It kept on increasing the number of ones at the end.
1) Macro Something
          define stval as string
          define endval as string
          stval=get integer"Starting Number"
          endval=get integer"Ending Number"
          stval=stval+1
end while
end macro
I got output as -1-A01 and the next number as -2-A01.
No luck:(
thendricks
3-Visitor
(To:sk-3)
I think it best if we go back to what you're attempting to do. '-0001-A01' is not a number (I might be missing something). I had assumed from your original request you were attempting to do the following. Start with '0001' then move to '0002' => '0003' => '0004' and so on.
Can you give an example of three 'sequential' numbers as well as what the input the values from your users are? Is the A01 consistent or does that vary? Might need to have a third input.
In regards to output, what output are your referencing? The create text line won't output the stval variable and there is no message line. Can you provide your full code to look at? If not, with the above requested information I should be able to provide an example, but you'll have to work on the implementation of course.
Hi Trevor, Thanks for your reply.. Below is the code I wrote.
Macro ICN
  define partno as string
  define ata as string
  define stng as string
  define base as string
  define base1 as string
  define base2 as string
  define base3 as string
  define base4 as string
  define pathI  as string
  define extI  as string
  define fname as string
  partno=get string "Part No."
  ata =get string "ATA"
  New
  text font "arial"
  text size 9
  open
  Select all
  Copy
  Close all_windows confirm_no
  New
  Run Macro
  Select all
  Delete selection
  PASTE same_position
  Select None
  Select at 143.189 6.634
  Delete Selection
  base1= "ICN-"
  base2="-A-"
  base3="-X-B-4050G-"
  base4="-A-001-1"
  stng=stval
  text font "arial"
  text size 9
  Create Text 153.711 8.4 base
  Select at 200.455 9.853
  Move Selection (-56.021) (-3.069)
  Move Selection (-0.145) 0.327
  extI=".iso"
  fname=base+extI
  pathI="G:\WORKING FOLDER\iso\"+fname
  save pathI
  stval=stval+1
  close  confirm_no
end while
End Macro
Output I want is
ICN-11111111-A-222222-X-B-4050G-0001-A-001-1
ICN-11111111-A-222222-X-B-4050G-0002-A-001-1
ICN-11111111-A-222222-X-B-4050G-0003-A-001-1 and so on..
-A-001-1 is a string that I am defining it in the macro itself. After running the macro I am getting as
ICN-11111111-A-222222-X-B-4050G-1-A-001-1
ICN-11111111-A-222222-X-B-4050G-2-A-001-1
ICN-11111111-A-222222-X-B-4050G-3-A-001-1 and so on..
Can you provide that example?. I will try to learn and replicate it. Thanks in advance.
thendricks
3-Visitor
(To:sk-3)
Macro ICN
    stng = stval
    base1= "ICN-"
      base2="-A-"
      base3="-X-B-4050G-"
      base4="-A-001-1"
      while (len(stng)<5)
        stng = '0' + stng
      end while
      message base
      stval=stval+1
   end while
End Macro
Thanks Trevor. I would surely test it out in my office and get back to you.
Thanks Trevor it worked..
