Publishing TM Getting error
MohitPatel
I am trying to publish TM that is around 8000 page. We can publish each chapter separately but when we combined into whole TM, we get this error .
PTC Arbortext Editor (Build 8.1.3.1-2) terminated unexpectedly at Fri Feb  6 15:21:47 2026:
[A17120] Assertion failed: size < TXF_MARK, file D:\jenkins\workspace\Adept_1\adept\src\pub\pub\edit\src\stortxt.cpp, line 534
Current ACL statement at "C:\progra~1\PTC\arbort~1\packages\main\_grhook.acl":264:
  264 [1]   return path
ACL function traceback at time of error:
#1   layout::format(doc=31, sourcedoc=31, sstype="", force=1) at "C:\progra~1\PTC\arbort~1\packages\main\_grhook.acl":264
#2   comp_pdf::pdf_postprocessing(doc=31, params=inParams[], interactive=1)
#3   compose::compose_for_type_int(doc=31, comp_type="pdf", interactive=1, inParams=inParams[], preprocessing_function="comp_pdf::pdf_preprocessing", dialog_function="comp_pdf::dialog_for_pdf", param_fixup_function="comp_pdf::pdf_parameter_fixup", postprocessing_function="comp_pdf::pdf_postprocessing") at "C:\progra~1\PTC\arbort~1\packages\tools\compose.acl":2672
#4   compose::compose_for_type(doc=31, comp_type="pdf", interactive=1, inParams=current_params[], prefn="comp_pdf::pdf_preprocessing", dialogfn="comp_pdf::dialog_for_pdf", paramfn="comp_pdf::pdf_parameter_fixup", postfn="comp_pdf::pdf_postprocessing") at "C:\progra~1\PTC\arbort~1\packages\tools\compose.acl":1761
#5   compose::compose_for_pdf(doc=31, batch_params=dummy[]) at "C:\progra~1\PTC\arbort~1\packages\tools\comp_pdf.acl":324
#6   compose_pdf() at "C:\progra~1\PTC\arbort~1\packages\tools\comp_pdf.acl":117
thank you
Just did a quick search of the PTC help
Looks like it has been asked before also with no solutions
https://community.ptc.com/t5/Arbortext/A17120-Assertion-failed-aptFalse-file-src-forsirtns-cpp-line/m-p/497907#M31261%3Fsource=search
https://community.ptc.com/t5/Arbortext/Error-A17120-Assertion-failed-size/m-p/231400#M16455%3Fsource=search
https://community.ptc.com/t5/Arbortext/blown-out-paths/m-p/190636#M13534%3Fsource=search
here are a couple from PTC support to look at.
https://www.ptc.com/en/support/article/CS410678?source=search
https://www.ptc.com/en/support/article/CS187410?source=search
Sotution:
Dear Customer,
Have you made any changes to this ACL? Did you customise this?
Manpreet Singh
MohitPatel
(To:manpsingh)
Thank you Manpreet and bfriesen,
we have not modified any ACL. Per PTC support ticket https://www.ptc.com/en/support/article/CS410678?source=search
I have test version of Editor 8.3.1. Ran thorough the same manual, I got signal 22 error.
Hello Mohit,
Did you also face the same error (along with what you mentioned above) mentioned in that article?
Manpreet Singh
MohitPatel
(To:manpsingh)
Hello Manpreet,
Yes, we got the same error when we used editor 8.1 as the article. When we used Editor 6.0 (we had old version on one of the PC), it worked fine without any error. When we tried Editor 8.3.1, we got error signal 22.
Hi Mohit,
Thanks for your response. It seems like you are getting different error messages using different Editor versions but with the same document and shared few articles above did not help resolving this issue. I would request you open a PTC TS case and we'll investigate it.
Please let me know if you've any question, thanks.
Manpreet Singh
