In our Arbortext installation, we have a customized print command that preprocesses our XML files before generating a PDF. Once the PDF has been generated, the customized command issues the license_release( "PrintPublishing" ) command before it finishes.
Most of the time this works just fine, but occassionally (a few times each month), the print composer license will not be released. Since we only have one license, I will usually hear from our users that they haven't been able to get a license for and hour or two. When I check the license server log, I can see which user last checked out the license. If I ask them the manually release the license (I wrote a menu item just for this), the license is released when they do so.
Is there anything more I can do to ensure that the license is released when the release_license command is issued?
Rick
Try to open a case with technical support: https://support.ptc.com/apps/case_logger_viewer/cs/auth/ssl/log
