Can anyone help me to solve this issue??
kc-2
when i try to launch windchill the following error is occur::
2015-07-13 04:06:14,447 INFO  [main] wt.system.out  - ------------------------------------------------------
2015-07-13 04:06:14,510 INFO  [main] wt.method.server.startup  - Starting MethodServer
2015-07-13 04:06:14,510 INFO  [main] wt.method.server.startup  - JVM id: 2376
2015-07-13 04:06:14,510 INFO  [main] wt.method.server.startup  - JVM: Sun Microsystems Inc., Java HotSpot(TM) 64-Bit Server VM, 1.6.0_31 (20.6-b01), 64-bit
2015-07-13 04:06:14,510 INFO  [main] wt.method.server.startup  - OS: Windows Server 2008 R2, amd64, 6.1
2015-07-13 04:06:14,510 INFO  [main] wt.method.server.startup  - Host: plm (plm.cadopt.com)
2015-07-13 04:06:14,510 INFO  [main] wt.method.server.startup  - Class path =
  C:\ptc\Windchill_10.1\Windchill\codebase
  C:\ptc\Windchill_10.1\Windchill\codebase\WEB-INF\lib\archiveClientWeb.jar
  C:\ptc\Windchill_10.1\Windchill\codebase\WEB-INF\lib\archiveServerWeb.jar
  C:\ptc\Windchill_10.1\Windchill\codebase\WEB-INF\lib\archiveWeb.jar
  C:\ptc\Windchill_10.1\Windchill\codebase\WEB-INF\lib\CounterPartWeb.jar
  C:\ptc\Windchill_10.1\Windchill\codebase\WEB-INF\lib\dpimplWeb.jar
  C:\ptc\Windchill_10.1\Windchill\codebase\WEB-INF\lib\dpinfraWeb.jar
  C:\ptc\Windchill_10.1\Windchill\codebase\WEB-INF\lib\Gantt.jar
  C:\ptc\Windchill_10.1\Windchill\codebase\WEB-INF\lib\ie3rdpartylibs.jar
  C:\ptc\Windchill_10.1\Windchill\codebase\WEB-INF\lib\ieWeb.jar
  C:\ptc\Windchill_10.1\Windchill\codebase\WEB-INF\lib\install.jar
  C:\ptc\Windchill_10.1\Windchill\codebase\WEB-INF\lib\jmxcoreWeb.jar
  C:\ptc\Windchill_10.1\Windchill\codebase\WEB-INF\lib\jviews-chart-all.jar
  C:\ptc\Windchill_10.1\Windchill\codebase\WEB-INF\lib\jviews-framework-all.jar
  C:\ptc\Windchill_10.1\Windchill\codebase\WEB-INF\lib\jviews-gantt-all.jar
  C:\ptc\Windchill_10.1\Windchill\codebase\WEB-INF\lib\mylyn-integration.jar
  C:\ptc\Windchill_10.1\Windchill\codebase\WEB-INF\lib\pdmlWeb.jar
  C:\ptc\Windchill_10.1\Windchill\codebase\WEB-INF\lib\prowtWeb.jar
  C:\ptc\Windchill_10.1\Windchill\codebase\WEB-INF\lib\reqlWeb.jar
  C:\ptc\Windchill_10.1\Windchill\codebase\WEB-INF\lib\rialtoWeb.jar
  C:\ptc\Windchill_10.1\Windchill\codebase\WEB-INF\lib\RMWebServices.jar
  C:\ptc\Windchill_10.1\Windchill\codebase\WEB-INF\lib\wc3rdpartylibs.jar
  C:\ptc\Windchill_10.1\Windchill\codebase\WEB-INF\lib\wncWeb.jar
  C:\ptc\Windchill_10.1\Windchill\lib\pdml.jar
  C:\ptc\Windchill_10.1\Windchill\lib\reql.jar
  C:\ptc\Windchill_10.1\Windchill\lib\servlet.jar
  C:\ptc\Windchill_10.1\Windchill\lib\wnc.jar
  C:\ptc\Windchill_10.1\Java\lib\tools.jar
  C:\ptc\Windchill_10.1\Windchill\tomcat\bin\bootstrap.jar
  C:\ptc\Windchill_10.1\Windchill\tomcat\bin\tomcat-juli.jar
  C:\ptc\Windchill_10.1\Windchill\srclib\wnc\WtAsmAgent.jar
2015-07-13 04:06:14,526 INFO  [main] wt.method.server.startup  - Setting WTContext time zone to America/Los_Angeles; offset: -7.0
2015-07-13 04:06:14,526 INFO  [main] wt.method.server.startup  - Setting default time zone to GMT; offset: 0.0
2015-07-13 04:06:22,463 INFO  [main] wt.pom.properties  - wt.pom.maxDbConnections=                 5
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.minDbConnections=                 5
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.dbConnectionsHardLimit=           0
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.dbConnectionsSoftLimitWaitTime=   0
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.dbConnectionsWaitTime=            0
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.connectionCloserThreshold=        0
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.connectionCloserIdleTimeout=      0
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.connectionMonitorSleepInterval=   10
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.lostConnectionCodes=              1012,3113,3114,12571,17002,17401,17008,17410
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.recoverableConnectionCodes=       0,28,1012,17002,17008
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.freeConnectionImmediate=          false
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.maxIdleStatementCaches=           0
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.jdbc.driver=                      oracle.jdbc.OracleDriver
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.jdbc.url=                         jdbc:oracle:thin:
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.jdbc.host=                        plm.cadopt.com
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.jdbc.port=                        1521
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.jdbc.service=                     wind
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.jdbc.database=
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.dbUser=                           wcadmin
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.dbSchemaUser=                     wcadmin
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.dbConnectionPropertiesNameList=
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.dbConnectionPropertiesValueList=
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.dbConnectionRetryCount=           1
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.userDefinedFunctionsFileName=     C:\ptc\Windchill_10.1\Windchill\db\userDefinedFunctions.xml
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.rowPrefetchCount=                 20
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.statementCacheSize=               50
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.cachedStatementReuseLimit=        50
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.feedbackInterval=                 500
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.interruptInterval=                50
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.cachedStatementRSLimit=           -1
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.implicitTransactions=             false
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.implicitTransactionsRollbackTime= 600
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.navigateDepthThreshold=           4
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.navigateDepthUnionLimit=          10
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.queryDepthThreshold=              3
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.queryDepthInClauseSizeLimit=      50
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.lobChunkSize=                     32000
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.log.JDBCStatements=               false
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.log.fileJDBC=                     null
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.log.filterJDBC=                   null
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.chunk.defaultSize=                50
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.objectReferenceQuerySize=         254
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.objectReferenceQueryChunkSize=    500
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.objectReferenceArrayTableEnabled= true
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.inflateHint=                      RULE
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.inflateSingleTableMode=           true
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.useBind=                          true
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.inClauseFixedSize=                5
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.inClauseSizeLimit=                1000
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.inClauseBindLimit=                51
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.inClauseUseBindOptimization=      true
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.inClauseBindOptimizationThreshold=50
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.inClauseBindOptimizationTempTableUsePrimaryKey=true
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.inClauseBindOptimizationCardinality=-1
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.cardinalityValueFixedSize=        100
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.tempTableNumberPerThreshold=      5
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.tempTableArraySizeNumberOfThreshold=3
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.tempTableArraySizeThresholdValues=200,1000, 2000
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.tempTable.insertChunkSize=50000
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.startupQueryLimit=                -1
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.queryLimit=                       -1
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.paging.queueInvokeTime=           600
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.paging.sessionCleanupTime=        1800
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.paging.threshold=                 -1
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.paging.insertChunkSize=           250
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.paging.fetchLimit=                15
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.paging.fetchSleepInterval=        1000
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.paging.closeSleepInterval=        600
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.paging.snapshotQueryLimit=        -1
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.paging.pagingSessionLimit=        5
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.statementCache.summaryInterval=   2000
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.enableNLSSort=                    true
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.constantArrayTableLimit=          4000
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.traceTiming.enable=               true
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.blobRead.handle620LV=             false
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.blobRead.handleOldLV=             false
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.blobRewrite.enabled=              false
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.selectForUpdateEnabled=           false
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.refreshCache.enabled=             true
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.refreshCache.summeryInterval=     0
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.refreshCache.size=                100
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.enableSQL99OuterjoinSyntax=       false
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.enableInListOptimizationWarning=  false
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.refIntegrity.ownerQuery.chunkThreshold=-1
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.refIntegrity.ownerQuery.roleChunkSize=-1
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.refIntegrity.ownerQuery.objectChunkSize=-1
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.refIntegrity.removeOids.objectChunkSize=-1
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.batch.spec.tableExpressionThreshold=5
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.batch.spec.useTableType=          true
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.batch.spec.useColumnList=         true
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.batch.spec.delete.classChunkSize= 2000
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.batch.spec.delete.chunkSize=      5000
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.batch.retry.enable=               true
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.batch.closePreparedStatement.threshold=-1
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.batch.insert.chunkSize=           100000
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.batch.update.chunkSize=           100000
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.maxQueryRetryCount=               5
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.oracle.blobInlineWriteThreshold=  -1
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.oracle.disableAlwaysSemiJoin=     true
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.oracle.jdbcConnectionMemoryLimit= 48
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.oracle.nlssort.truncateLength=    600
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.emptyTableQueryClassChunkSize =   400
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.resultSetThreadPool.size =        2
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.resultSetThreadPool.queueSize =   -1
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.resultSetThreadPool.implicitEnabled=false
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - wt.pom.pdsDecoderBypassUserLoader =      true
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - Windchill DataStore: Oracle
2015-07-13 04:06:22,541 INFO  [main] wt.pom.properties  - JDBC Driver Version: major=11 minor=2
2015-07-13 04:06:22,885 INFO  [main] wt.method.server.startup  - MethodServer created - port 5003
2015-07-13 04:06:22,885 INFO  [main] wt.method.server.startup  - Starting services - class = wt.services.StandardServicesHandler
2015-07-13 04:06:49,291 INFO  [main] wt.pom.properties  - wt.pom.delete.triggerClassNames=
2015-07-13 04:07:27,026 ERROR [main] wt.method.server.startup.services  - Failure to start manager wt.audit.StandardAuditService
wt.services.ManagerException: Could not initialize Auditing service.
Nested exception is: wt.ufid.UfidException: wt.pom.DatastoreException: A SQL error has occurred. Database system message follows:
  wt.pom.ConnectionException: A SQL error has occurred. Database system message follows:
  java.sql.SQLRecoverableException: ORA-01033: ORACLE initialization or shutdown in progress
Nested exception is: wt.pom.DatastoreException: A SQL error has occurred. Database system message follows:
Nested exception is: wt.pom.ConnectionException: A SQL error has occurred. Database system message follows:
Nested exception is: java.sql.SQLRecoverableException: ORA-01033: ORACLE initialization or shutdown in progress
  at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:445)
  at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:389)
  at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:382)
  at oracle.jdbc.driver.T4CTTIoauthenticate.processError(T4CTTIoauthenticate.java:441)
  at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:450)
  at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:192)
  at oracle.jdbc.driver.T4CTTIoauthenticate.doOSESSKEY(T4CTTIoauthenticate.java:404)
  at oracle.jdbc.driver.T4CConnection.logon(T4CConnection.java:385)
  at oracle.jdbc.driver.PhysicalConnection.<init>(PhysicalConnection.java:546)
  at oracle.jdbc.driver.T4CConnection.<init>(T4CConnection.java:236)
  at oracle.jdbc.driver.T4CDriverExtension.getConnection(T4CDriverExtension.java:32)
  at oracle.jdbc.driver.OracleDriver.connect(OracleDriver.java:521)
  at java.sql.DriverManager.getConnection(DriverManager.java:582)
  at java.sql.DriverManager.getConnection(DriverManager.java:154)
  at wt.pds.StandardDataSource$2.getConnection(StandardDataSource.java:235)
  at wt.pds.StandardDataSource$ConnectionRetry.execute(StandardDataSource.java:367)
  at wt.pds.StandardDataSource.getConnection(StandardDataSource.java:238)
  at wt.pds.StandardDataSource.getConnection(StandardDataSource.java:80)
  at wt.pds.oracle81.OracleDataSource.getConnection(OracleDataSource.java:64)
  at wt.pom.WTConnection.connect(WTConnection.java:291)
  at wt.pom.WTConnection.<init>(WTConnection.java:275)
  at wt.pom.PersistentObjectManager.connect(PersistentObjectManager.java:313)
  at wt.pom.POMHandler.getConnection(POMHandler.java:133)
  at wt.method.MethodContext.getConnection(MethodContext.java:2051)
  at wt.pom.PersistentObjectManager.getUserConnection(PersistentObjectManager.java:322)
  at wt.pom.PersistentObjectManager.query(PersistentObjectManager.java:1099)
  at wt.pom.PersistentObjectManager.query(PersistentObjectManager.java:1015)
  at wt.fc.StandardPersistenceManager._query(StandardPersistenceManager.java:1829)
  at wt.fc.StandardPersistenceManager._find(StandardPersistenceManager.java:1858)
  at wt.fc.StandardPersistenceManager.find(StandardPersistenceManager.java:675)
  at wt.fc.StandardPersistenceManager.find(StandardPersistenceManager.java:427)
  at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
  at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
  at java.lang.reflect.Method.invoke(Method.java:597)
  at wt.services.ServiceFactory$ServerInvocationHandler.invoke(ServiceFactory.java:399)
  at $Proxy9.find(Unknown Source)
  at wt.ufid.FederatableServerHelper.getRepositoryFromDB(FederatableServerHelper.java:1854)
  at wt.ufid.FederatableServerHelper.getRepository(FederatableServerHelper.java:228)
  at wt.org.StandardOrganizationServicesManager._getRepositoryForService(StandardOrganizationServicesManager.java:9212)
  at wt.org.StandardOrganizationServicesManager._getDomainsForPrincipals(StandardOrganizationServicesManager.java:9325)
  at wt.org.StandardOrganizationServicesManager.getDomainsForPrincipals(StandardOrganizationServicesManager.java:9242)
  at wt.org.StandardOrganizationServicesManager._queryPrincipals(StandardOrganizationServicesManager.java:7302)
  at wt.org.StandardOrganizationServicesManager._queryPrincipals(StandardOrganizationServicesManager.java:7129)
  at wt.org.StandardOrganizationServicesManager._queryPrincipals(StandardOrganizationServicesManager.java:7105)
  at wt.org.StandardOrganizationServicesManager._queryPrincipal(StandardOrganizationServicesManager.java:7050)
  at wt.org.StandardOrganizationServicesManager.getAuthenticatedUser(StandardOrganizationServicesManager.java:2196)
  at wt.org.StandardOrganizationServicesManager.getUser(StandardOrganizationServicesManager.java:2341)
  at $Proxy19.getUser(Unknown Source)
  at wt.session.StandardSessionManager.getUser(StandardSessionManager.java:390)
  at wt.session.StandardSessionManager.getAdministrator(StandardSessionManager.java:272)
  at wt.session.StandardSessionManager.setAdministrator(StandardSessionManager.java:250)
  at $Proxy18.setAdministrator(Unknown Source)
  at wt.audit.StandardAuditService.performStartupProcess(StandardAuditService.java:297)
  at wt.services.StandardManager.startup(StandardManager.java:459)
  at wt.services.ManagerImplementation.startup(ManagerImplementation.java:356)
  at wt.services.DefaultStartupHandler.startup(DefaultStartupHandler.java:112)
  at wt.services.StandardManagerService.performStartupProcess(StandardManagerService.java:166)
  at wt.services.StandardServicesHandler.start(StandardServicesHandler.java:44)
  at wt.method.MethodServerMain.run(MethodServerMain.java:410)
  at wt.method.MethodServerMain.main(MethodServerMain.java:257)
2015-07-13 04:07:27,088 INFO  [main] wt.method.server.shutdown.services  - All managers shut down.
2015-07-13 04:07:27,088 ERROR [main] wt.method.server.startup.services  - Unable to start all managers.
(wt.services.servicesResource/21) wt.services.ManagerException: Unable to start manager: "wt.audit.AuditService" with implementation class: "wt.audit.StandardAuditService"
Nested exception is: wt.services.ManagerException: Could not initialize Auditing service.
2015-07-13 04:07:27,166 FATAL [main] wt.method.server  - MethodServerMain abort
wt.services.ManagerException: Unable to start all managers.
Nested exception is: (wt.services.servicesResource/21) wt.services.ManagerException: Unable to start manager: "wt.audit.AuditService" with implementation class: "wt.audit.StandardAuditService"
2015-07-13 04:07:27,166 FATAL [main] wt.method.server.shutdown  - Stopping services...
2015-07-13 04:07:27,166 INFO  [main] wt.method.server.shutdown.services  - All managers shut down.
2015-07-13 04:07:27,166 FATAL [main] wt.method.server.shutdown  - MethodServer stopped
MaxR.Kublin
(To:kc-2)
Try to move this to the Windchill Forum to increase the chance of getting help.
MaxR.Kublin
(To:kc-2)
Well, after having a second look at the error trace, your problem is clearly:
in Progress
Means that your Database did not start up correctly.
Before attempting to start the method Server you Need to fix the problem with your Oracle Database.
kc-2
(To:MaxR.Kublin)
Thanks Max. let me check ...
MaxR.Kublin
(To:kc-2)
Any results? Success?
