Can not use ampersand (&) text symbol?
ptc-4684951
1-Visitor
Does anyone know how I can create an Ampersand (&) text symbol, or a shortcut to use it as text in a symbol? Creo does not allow "&" as text in my title block symbol?
Try this:
In title value, type S > press CTRL+A > SHIFT+7 (For &) > press CTRL+B > W
14 REPLIES 14
sm
(To:ptc-4684951)
In Creo Parametric 2.0, whenever the characters & or @ must be display in the text of a note, type them twice: for example, type [See Views 1 && 2 @@ Sheet 3] for the note to read See Views 1 & 2 @ Sheet 3.
ptc-4684951
1-Visitor
(To:sm)
Thank you Scott. I am currently using Creo 1.0. I am actually trying to edit variable text in a symbol. In this case it is my company title block for the drawing. When I type & or && the line of text blanks out on the drawing?
sm
(To:ptc-4684951)
Can you add a screen shot of your example? Want to make sure we're all talking about the same thing. Could be table text. note text, symbol text or parameter text.
ptc-4684951
1-Visitor
(To:sm)
Ampersand seems to work on its own in symbols but not with other text.
There must be some sort of delimiter that allows this.
Video Link : 5301
dm-3
(To:sm)
Is it possible to include value of a parameter in subscript or superscript?
Dhinesh
Try this:
It worked! Thank you!!
What exactly is the Ctrl-A and Ctrl-B doing?
Ctrl-A and Ctrl-B are Start and End delimiter.
... and how do you file this in the memory banks for when you need it....
Not to memorise
Check this out
Aha! That's what I thought. This needs to go in the text tips.
Linked!
Tips for text
cspinelli
(To:Mahesh_Sharma)
where can i find the special font used in this combination? if know that there is special.fnt but i cannot see where to modify one of that font..
thanks
