End of a paramter in a text string
Dale_Rosema
When you write a parameter in a text string, &parameter_name, is there a when to let the text know that the parameter is done other than a space? i.e. &parameter_name_COLOR where Parameter_name is the name of the parameter and _COLOR is attached to the end (without a space between them).
Thanks, Dale
Dale, you can fool the system by using the old world delimiting with the curly braces "{0:&variable}".
In this manner, you can void the spaces all together.
This is from here:
Antonius Dirriwachter wrote:
Nono... I meant write a note that is independent of the hole itself. You might be able to assign some of the variables in a note, but even that has gotten harder.
My favorite method is to use a radial dimension and edit to a hole note. That way, the leader will remain normal to the edge.
I also a issues with the SAE callouts where spaces are added at the dash (UNC-2B reads UNC - 2B). Funny enough, there is a way to avoid the excess spaces:
Re: Tips for text
Also found this:
If you have a string of variables like in hole callouts, you noticed that you require spaces between the end of the variable and new text characters. This is why you see...
&THREAD_SERIES - &THREAD_CLASS
UNF - 2B
...a text string which is obviously not to any standard that we as engineers accept.
But there is a little known method to remove the requirement for the space:
{0:&THREAD_SERIES}-{1:&THREAD_CLASS} ...which returns
UNF-2B
Old school editor but this is what makes it work.
Why didn't PTC do this for the hole CALLOUT_FORMAT?
PTC, are you listening? This is what "we" call fit and finish
I know we have discussed this before but I need to find it again.
Dale_Rosema
(To:Dale_Rosema)
If not, is there a way to do a half space (like the old fashion typewriter).
This is from here:
Re: Tips for text
Also found this:
UNF - 2B
UNF-2B
Dale_Rosema
(To:TomD.inPDX)
Antonius,
That worked great for the variable/parameter, but guess what!!! It didn't work for &dwg_name!!!
Any thoughts on that? When I put the { } around &dwg_name it showed {actual drawing name}
Dale
I just tried it again with the {0:&dwg_name} and it works!!!!
It changes the zero to whatever number it wants, but if you don't put in the zero and the colon, it doesn't work.
If you use the standard [ ], it automatically puts in the #: in the text.
Dale_Rosema
(To:Dale_Rosema)
Gotta luv Pro/Creo
