How Can I Open SolidsWorks Files in Creo 3.0??
melias
3-Visitor
Hello Friends, Can Somebody help me with this issue??
ME
If you type "open solidworks" in the right upper corner of this discussion, you can find other discussion on the same argument.
Marco
Thank you!!!
Mauricio,
File > Open > change filter settings to see sldprt files > select file > Open
Martin Hanak
Thank you!!
