I created several snapshots to make an animation with in Creo Parametric. I created the key frame sequence, but when I try to play the animation I keep getting the following error "Key frame sequence Kfs1 invalidated and will be ignored." What does this mean? How did I get an invalidated key frame sequence and how can I correct it? Has anyone had this problem before? I am not sure where to start because I did the process exactly as I have before, and it worked previously.
Setting all the bodies to desired resolved the issue. Don't know why the bodies can't be unspecified or required on this animation though.
