Importing DXF files into Isodraw 7.3 M030 not working
hhobson
2-Guest
I am having trouble importing dxf files into Isodraw 7.3...It works in my previous version F000... any clues?
Heather,
I reproduced the problem on my PC.
I opened your DXF file in Notepad and realized that $ACADVER=AC1009. This is AutoCAD Release 11,12 format, i.e. very old format.
I opened your DXF file in Creo Parametric 2.0 as drawing and reexported it in AutoCAD Release 2007 format. This file can be opened in Isodraw.
So ... it looks like Isodraw does not understand old AutoCAD format ...
Martin Hanak
Heather,
can you upload some DXF example ?
Martin Hanak
Here is the file I am on about. I have given it a new name and still does not work
Heather,
Martin Hanak
Many thanks Martin, I will get the AutoCAd sent n a newer format.
