Making a hole diagonal of rectangle
ptc-5385523
hey there guys...this is nothing to do with d original post up there..
i just had a problem n i m looking for somebody to sort it out for me..
I WANT TO MAKE A HOLE ALONG D DIAGONAL OF RECTANGLE IN PRO-ENGINE
see if anybody could help me out
Branched this discussion from another where it didn't belong, hopefully one of our experts can answer Sandeep's question here.
Thanks Ryan.
Sandeep, welcome to the forum.
Two ways of making holes when you do not have a good surface for placement:
  • Create a plane where the hole can be placed and located.
  • Create a revolved cut in the shape you require. You can later add a cosmetic thread in the hole if desired.
Inoram
(To:ptc-5385523)
Like this?
Gotta create an axis and datum (on the fly to bury these features if you wish), then remove the datum reference first, then re-select the axis, THEN the datum (a pain), but it works and is pretty easy.
