Peck Tables
ToddWoodall
Peck Tables
Anyone using peck tables? If so would you be willing to share and example?
Thanks in advance.
Todd,
If you click on Jim barret-Smiths link to the EMX tutorial in the previous post. on the left side of the page if you scroll down there are tutorials for manufacturing and in those there is a hole making section with a good example of a peck table with an example of the output
Todd,
