Does anyone have an opinion on this or have a pros vs cons of each?
Upload pushes a copy of the saved file to the server-side workspace in which is resides. This means the saved file can be accessed from another workstation if that user needs to do so. (For instance, if the modifications are not going to be checked in.) This also means on the rare occasions a workstation is changed or suffers a mysterious crash, every save will be retained even without a check in.
I keep our config set to automatically upload on every save. While some of my users even pay attention to when an upload fails and try to resolve the issue right away, most just ignore it because there are so rarely problems associated with it.
I've made sure the configuration is set this way at two previous positions as well.
The downside is (supposedly) network traffic. I've never seen any slow-down from the user's standpoint and no IT department has ever complained about the network traffic from this. (Though to be fair, they may not be able to tell between the automatic uploaded files and a legitimate upload/checkin without extra work.)
If I were to make a recommendation, I'd say to set your config.sup to dm_upload_automatic YES and let the users just pick Save.
Simplest rule of thumb I've given to users is upload when working with reasonably sized files (whatever that means). When working with large files save during the day and upload before you go home.
With all due respect to Dan's position, there are a couple things I'd like to point out.
First, the customers I've had to deal with generally don't give a crap about being educated in this regard. And by customers I mean the coworkers I have to support. The engineers and designers want to get on with designing. The drafters just want to get on with model/drawing creation and clean-up. The checkers just want to get on with checking. The people assigned various roles in workflows want to get on with their job.
I've had a few over the years ask what upload does out of real curiosity. I've yet to see one get through the explanation without losing interest. As long as the software works from their vantage point they don't care about the rest.
Second, if an organizations systems are so close to the edge that the automatic upload causes a problem due to bandwidth, disk space or table space, there are more serious and immediate problems to deal with than this.
I am new to all this and currently tweaking our Windchill 10.1 configuration. I have no data migrated yet.
We did choose to automatically upload with each save because our assemblies are small and we have a Fiber backbone that is very fast.
You simply need to consider your infrastructure and make the best call for your situation. We have the speed and our files are not large so we decided the server side workspace gives us peace of mind that our work will not be lost due to corruption or a users computer crashing.
I am still learning, so I really enjoy all the feedback from veterans.
"Too many people walk around like Clark Kent, because they don't realize they can Fly like Superman"
Thanks for the responses. I always push the full check-in as the safest method, but I also try to expain the differences between the save vs. upload options (which most of the users get a glazed look on their faces because they don't really care how it works, they just want it to work all the time).
Personally I always played it safe and performed the save and upload instead of the save only when I was part of product design. The other issue that I face with the CAD users I support is thatI have only been the CAD admin for about 5 months. I used to work under alot of the people I know train and support so the advice on best practices that I offer are often looked over or not taken seriously.
John Bennett
CAD Business Admin
Lifetime Products
Automatic is correct. I must have remembered an older version of that config being YES.
(Or maybe even a different config, knowing how my memory works!)
In Reply to LEONID GUREVICH:
I want to check next spelling - "dm_upload_automatic YES", is it true?
I have in my config.pro next row: "dm_upload_objects automatic"
A user at our site saved & upladed his files. He then cleared his workspace & deleted his cache without thinking to check-in the objects. Doesn't deleting the cache only affect the local workspace? How do you recover the data from the server-side workspace when nothing is showing up?
