Are skeleton file not used in Creo3.0? I can't find the command. Skeleton is not a keywork in serch.
It would be odd if it's not there. It's a subtype of part, as in New -> Part - Skeleton or Part - Bulk Item.
I guess skeleton model can be created in Assembly mode, only.
MH
Yes, Skeleton parts can only be created within the context of an assy. It's always been that way, I believe.
And they are still in Creo 3, assuming you have an AAX license.
Thankyou, I did find it where David said it would be. I just had a bran fart, Thanks again
James,
You may mark David's reply to post as correct answer as that helped you
