see pic
if i change connection from cylinder to pin it will show its name but not in cylinder connection why?? unable to find.....
Hi
If you have enabled Enable regeneration value; then you should be able to see the value by edit option.
Right click on the second part (of the cylinder connection)and select edit as shown in the picture.
K.Mahanta
still waiting
I know in Creo Pro E 5.0, you can right click on the feature, select edit, and then select and right click the dimension and choose properties - this will show you the name and also allow you to rename it.
thanx 4 ur rply but problem is it do not show dimension (in edit mode) which im pointing in pic..
Hi
K.Mahanta
