I had an Excel sheet working nicely with Creo 2, and all of a sudden I started getting automation errors while trying to connect. The error is "Run-time error 2147417851 (80010105), Automation error. The server threw an exception."
The only way I can clear it is to restart the PC. It will work fine a few times, and then throw it again. I can't find anything that would cause it, and it always happens while trying to connect.
Set oConn = oAsynConn.Connect (Null, Null, Null, 5).
Once it trips, I get the error regardless if I stop and restart excel, and it doesn't matter if Creo is open or not. It also happened when I tested on a different machine with the same spreadsheet. I've unregistered/re-registered the component, checked the references, etc. All looks fine.
Any ideas?
From PTC support... the COM process can sometimes hang during a non-trapped error. The solution is to manually kill the pfclscom.exe process.
This error should be related to Excel, not to connect. I would suggest to check how is the Excel object created.
Try to google this error number, there are many issues on this error code - for example this on: run-time error '-2147417851 (80010105)'
Tom
Only happens with reference to Creo library though, and only when code execution stops (debug mode).
Could you post some minimal code and tell how are you creating the references to the COM libraries?
