EMX 7.0 M030 is compatible with Creo 2.0. It should be stable when you work withthe data created in V5.0~.
As forEMX 4.1 legacy data, it is always not that easy since thesystem haschanged a lot in 5.0.Contact B&W to get help onmigrating thelegacy data to the new settings.
If you have done customization in EMX 4.1, I would suggest you redo them in the new version but not use them directly.
Russell Hsu
