Custom IFX Library
JR_8255297
Custom IFX Library
Hi @OliverGräbner
I would like to create a fastener library compatible with the IFX module.
First, I am trying to link an existing family table with the keyword FAMTABLE.
To do this, I have created a .dat file, as shown below
SCREWTYPE 1
UNIT MM
SURFACE 49
AXIS 82
CBSCR DIN974-1 R1
INFO <Screw_test>
!Enter the name of the Family Table Part
FAMPRT VIS_CHC_INOX_JY
SYMBOL STRING DN LG B S DK K DG P
INSTANCE STRING DN LG B S DK K DG P
#FAMTAB M<DN> d4 d6 d15 d17 d5 d7 d16 @pas
My family table contains several instances using an item code for each instance.
When I launch IFX, the thread box remains empty and I cannot choose a screw size.
I also get the following error message:
No valid data found
DN Vis_chc_inox_jy.dat
I think I have a problem with the STRING box in my .dat file.
I tried with a family table with two instances and simpler file names, but nothing changed.
I looked at all the posts, but none of them answered my question.
Could you please help me?
This is my first step. Next, I would like to link my tables, but in Windchill.
Creo 10
10 REPLIES 10
can you please attach your simple part and your *.dat file.
Then I will check it on my side and give you feedback.
Oliver Gräbner
B&W Software GmbH
Hi Oliver,
Thank you for your quick answer;
You will find attached our dat file and two differents prt files.
One is a test part with 2 instances and the other our official part family table
Best Regards
Jonathan
you must use tabs between your values.
I also have changed  @pas to PAS.
That's all.
Find attached the modified file.
Oliver Gräbner
B&W Software GmbH
one more hint.
I recommend to use Notepad++ (Show tabs and spaces) together with plugin Columns++ (Elastic Tabstops)
Github: Columns++ plugin for Notepad++
Oliver Gräbner
B&W Software GmbH
Thank you Oliver!
For washer, does it work the same way with family table?
How does it match the size of screew and washer?
Is it preferable to make a family table by material and by size of washer (large, small, medium)?
here we go.
- Yes, same process as for screws and nuts.
- You need a dimension or parameter (DN) for the screw diameter
- if you only have inner and outer diameter it will not work
- this is up to you.
- it depends on the rest of your library-structure - you should keep it consistent.
- you can use one *.dat file for each material or you can use a column with material und use SUBINFO to select the material/size after selection the washer
Did you know about SUBINFO in IFX - PTC Community
- you can use a kind of filter inside your *.dat file to filter for material or size parameter
Fastener Data Files - see MUST and NOT for family tables
Oliver Gräbner
B&W Software GmbH
Thank you,
Is it ok like that?
because it doesn't work.
I don't see washer and nut on the interface
looks good from the png.
ensure you have a diameter (e.g. M6) availabe for the nut and washer,
if not, they will be removed and the option menu stays empty.
If I should verify it, please send your files (*.dat and *.prt).
You can also provide it to me by mail if you do not want to share it here.
oli@buw-soft.de
Oliver Gräbner
B&W Software GmbH
Thank you for your help,
It works now! the # was missing
Is it a way to manage headless screews with IFX in tapped blind holes or tapped through holes in order to have automatic diameter selection? same question with pins?
Best Regards
for setscrews you do not have the possibility to enter a offset depth to the placement surface.
So setscrews are not supported right now.
For dowelpins this is possible.
Please send me a little bit more details, then I can review your request.
Oliver Gräbner
B&W Software GmbH
