I'm having trouble getting a volume sequence to output with a G41. I have the comp parameter turned ON and a small lead in/lead out radius value. I also have a small .010 tangent step with a 90 deg approach and exit. I've used volume sequences before with C-comp successfully. Don't know what I'm doing wrong this time? Any help would be appreciated.
Matt.
do you have the "rough_option" parameter set to profile? Also "cut_entry_ext" to lead_in. and "cut_exit_ext" to lead out.
Hello Matt,
Please let us know, what was eventually the outcome!
Did Son's suggestion help you solve the issue?
If yes, please take the time to mark it as Correct Answer, to let community know the question has been answered.
Gunter
The "rough option" was set to "rough and prof" with the profile stock allow set to "0". I didn't see the "cut_entry_ext" or "cut_exit_ext" option you mentioned. I did have the "lead_in" and "lead_out" option set to "yes" for both.
After I posted my comment, I was messing around with different setting options, I ended up remaking the sequence with the same parameters and it then posted with the G41 like I was looking for. Hmmm.
Thanks for your suggestions.
