Hello!
I am compiling my Toolkit Wildfire 4.0project in Visual Studio 2005.
But the builded dlls is very great.It's haves 13.860 Kbytes.
Thanks, Diogo.
Patrick!
I saw the examples of the Protoolkit (pt_examples.dll)and the dll is very great.
Thanks.
Hi all,
Interesting discussion.
Here is what I got from PTC support some time back:
You opened 6829265 with PTC Technical Support on 12-Jan-2009, with the following description:
"Debug information is included in protk_dll.lib file. This cause VS2005 debugger to look for the original source files."
After further investigation, I found that SPR 1462374 was filed to reports the issue "While using ‘protk_dll.lib’ of Wildfire 4.0 release, the Size of TOOLKIT DLL increases by a factor of 9 to 10".
From this SPR, I understood that the debug information was provided intentionally with Pro/Toolkit library files to benefit the customers.
Based on the past feed back from Tech support (customer reported issues), this debug information was added to Pro/Toolkit libraries to generate better crash dump information if a crash occurred in a Pro/Toolkit app at customer’s end.
However, the SPR did not mention about VS2005 looking for source files while debugging Pro/TOOLKIT applications. I requested PTC development to check this issue and confirm. I’ll update you as soon as I hear from them.
Sincerely,
Seshu Kumar
Technical Support Engineer, Senior
============================================================================It looks like quite a number of factors had influenced dll file size increase.
FV.
FYI - I opened a similar call complaining about large DLL's and the refrenced the closed SPR you found 1462374
I did some more looking and found another Open SPR - Severity High - 1985138 - that makes more sense and shows there is something that PTC can do to correct this issue. See PTC SPR Description below:
Hi together,
are there any news regarding the big Pro/TOOLKIT DLLs?
Has anybody a solution how to decrease the filesize?
Best regards, Domenic
Hi together,
I don't know anything about the big toolkit dlls, but I know that OTK Dlls are bigger. Smallest OTK Example I build is 28 MB. So I think the size doesn't matter for PTC. But don't know.
Best regards,
Eike
