GET SECTION VIEW BACK
dbolden
Somehow I lost the section C-C cutting plane.  How do I get it back?
How do I not show the (2) blue lines which I believe are used to construct Section C-C cutting plane.
StephenW
(To:dbolden)
In the message log, is it telling you anything, like possibly, section c-c aborted?
Try to do a Resume all features. The Cross section may have been suppressed accidentally.
dbolden
(To:dbolden)
Where do I find Resume all features?
dbolden
(To:manjunathrv)
I managed to get the section view back but I cannot get rid of the blue line "Sketch_2".  I do not know what this line is.  When I look at each feature to see where Sketch_2 is, they all just say Section 1.  Any idea how to hide this blue line or at least find out what it is related too?
StephenW
(To:dbolden)
If you go to the model and delete sketch_2, does it try to delete other features? If so, it is used as a reference to those features.
Could that sketch feature be used in a higher level assembly maybe? You would then not want to delete them.
You can add them to a layer in the model (they may already be on a layer) and hide that layer in the drawing if you can't delete the feature.
StephenW
(To:dbolden)
In the model, you can also use the reference viewer on the tools tab to investigate references. It's not too hard to learn but it's a powerful tool to that will prove useful in the future.
dbolden
(To:StephenW)
Winner !!  Great job Stephen.  It must have been hidden so the sketch_2 wasn't showing.  I went into Tree Filter and checked Feature, Annotations and Suppressed Items.  One of those turned the sketch back to visible in the tree.  I hid that sketch and like magic the blue line is gone.  Thank you VERY much.
