How to Install, Register, & Configure Creo VB API
PARTHIBAN_K
Hi Friends, I have created an article to install, register, & Configure Creo VB API. Take a look on this link and give your feedback
How to Install, Register, & Configure Creo VB API Toolkit component in Creo Parametric - PARTHIBAN KANNAN
Parthiban Kannan
href="https://www.linkedin.com/in/parthiban-kannan/" target="_blank"
10 REPLIES 10
msteffke
(To:PARTHIBAN_K)
Thanks Parthiban.   These steps can be confusing to figure out if you are just using the PTC docs.
SYNDAKIT
(To:PARTHIBAN_K)
YES! This is great. Please keep the VB articles coming.
I have been pulling my hair out trying to do this.
thank you!
Hi Parthiban, trying to download the guide but getting a web error, is it still available ?
Hello Bill Lamb
It is working, check it now
Parthiban Kannan
Hi Parthiban ,
Thanks for fixing, I am reading it now.
Article moved to this link
http://creocustomization.com/2017/02/24/how-to-install-and-register-creo-vb-api-toolkit-component-in-creo-parametric/
Parthiban Kannan
I don't know how to edit my own comments? I could not found any options to edit.
So the new updated link
http://creocustomization.com/how-to-install-and-register-creo-vb-api-toolkit-component-in-creo-parametric/
Parthiban Kannan
Now the same article added to medium
https://medium.com/@parthiban_kannan/how-to-install-register-configure-creo-vb-api-toolkit-component-in-creo-93cd9dad53a3
Parthiban Kannan
NSS
(To:PARTHIBAN_K)
Hi Parthiban,
Could you please help on how to start with the Creo VB API programming.
will you share any simple program to start with this coding, if possible.
Regards!
Senthilnathan.S
Hi Parthiban,
I'm trying to make the toolkit functional.
What else needs to be installed, see page 14-15 vbug.pdf file on
"C:\Program Files\PTC\Creo 8.0.3.0\Common Files\vbapi".
I followed the instuctions on page 13 up to "Setting Project References for the VB API".
Many thanks in advanced for the time thet you can dedicate to me.
Luca.
