I have would like to assign a spesific photolux color (adv-steel) for my .mtl file but the color won't show up in the model.
Here is the file that I'm trying to use
ND_RelParSet_K01 = {
Name = BFACJ
PARAMETERS =
Name = PTC_MATERIAL_DESCRIPTION
Type = String
Default = 'BFACJ'
Access = Full
Name = TEMPERATURE
Type = Real
Default = 0.000000e+00 C
Access = Full
Name = PTC_INITIAL_BEND_Y_FACTOR
Type = Real
Default = 5.000000e-01
Access = Full
Name = PTC_BEND_TABLE
Type = String
Default = ''
Access = Full
Name = PTC_MATERIAL_TYPE
Type = Integer
Default = 9
Access = Locked
Name = PTC_FAILURE_CRITERION_TYPE
Type = String
Default = 'NONE'
Access = Locked
Name = PTC_FATIGUE_TYPE
Type = String
Default = 'NONE'
Access = Locked
Name = PTC_MATERIAL_SUB_TYPE
Type = String
Default = 'LINEAR'
Access = Locked
Name = PTC_MASS_DENSITY
Type = Real
Default = 0.285 lb/in^3
Access = Full
Name = PTC_POISSON_RATIO
Type = Real
Default = 3.300000e-01
Access = Full
Name = PTC_YOUNG_MODULUS
Type = Real
Default = 1.010000e+07 psi
Access = Full
Name = PTC_THERMAL_EXPANSION_COEF
Type = Real
Default = 1.310000e-05 /F
Access = Full
Name = PTC_DEFAULT_APPEARANCE
Type = String
Default = 'adv-steel'
Access = Full
Name = PTC_APPEARANCE_1
Type = String
Access = Full
I followed below mentioned steps.
insert the definition of adv-steel color into global.dmt file and ... you are done.
I did exactly what you said but it's not working...
please put into zip file your Creo part and global.dmt file and upload zip file using Browse button. I will check your data.
AWESOME!
My problem is solved.
I think that the problem occured beacuse I had not created bfacj.mtl file in E:\PTC\Creo3_M120\Creo 3.0\M120\Common Files\text\materials-library directory. Now all the colors are correct. This saved my day!
Thanks Martin!
Hi Martin,
I know this is from over a year ago, but I am having trouble with the solution in this post.
I edited the .mtl file to include the PTC_DEFAULT_APPEARANCE. I used one of the appearances that was already defined in our global.dmt.
It worked at first as I was assigning the material to new parts. But the next day when I started a new session, the appearance was overwritten to be white. When I go into the properties of the material and go to the appearance tab, the default appearance somehow got overwritten to be white.
So for example. There was a ptc_gold appearance in the golabl.dmt. I edited our .mtl file for our gold material so that the default appearance would be ptc_gold. So at first when I assign gold, the parts would be yellow. But the next day the parts would be white.
No idea why they are becoming white.
I am planning on creating a new community post for this problem.
What version and build? You are the second person today to say there is an issues with assigning colors in the material files. It may be a bug in the build of Creo.
Creo 3.0, M110.
Won't make the change to Creo 4.0 for a few months.
I tested assigning .mtl file color inCreo 3.0, M110 with success.
In my E:\PTC\Creo3_M110\Creo 3.0\M110\Common Files\graphic-library\appearances\global.dmt file there is gold_ptc color. No ptc_gold color is present.
I attached bronze_mh.mtl file I used during testing.
If I changed color name in bronze_mh.mtl file to non-existing color name (I edited file in Notepad++), created new part and assigned material ... I get white colored model.
