Java Tool can't load in disply
ddhini
I made a tool using J-link and Java .I successfully loaded my tool in creo Session using Auxiliary Application=>Register an it loaded Successfully.When I click the button to open the tool then it will load but can't get the tool in-front of display. Everytime I am Using Alt+Tab and access the tool.Please help me to solve this .Thanks in advance.
sjuraj
(To:ddhini)
Well, this is matter of Java not a J-link.
Solution could be to set JDialog always on top (see docs Window (Java Platform SE 7 )).
If you need your dialog to be shown on top of Creo only, you will probably have to make windows event hook using JNI (or JNA) and user32.dll library, but I cant give you any example, you will have to search for solution on internet.
10 REPLIES 10
sjuraj
(To:ddhini)
If you are using Swing tool then it is normal behaviour. You can set Swing dialog AlwaysOnTop.
ddhini
(To:sjuraj)
Sorry ,Give me a brief explanation.
sjuraj
(To:ddhini)
What is the tool which is not in-front ? Is it JOptionPane ?
ddhini
(To:sjuraj)
No it is a JDialog .When i entered first time in proe  i click the button to open my tool .But it cant loading.I am using Alt +tab key to bring that front.But afterwards its working perfect
sjuraj
(To:ddhini)
ddhini
(To:sjuraj)
Yes you are absolutely right. j dialog is set to front but   am using j frame to show some message in between process.But it can't load but it opened in background.how to rectify this?
sjuraj
(To:ddhini)
You have to search on the internet. This can be useful java - Is it possible to bring JFrame to front but NOT focus? - Stack Overflow
ddhini
(To:sjuraj)
Thank you, am trying....
ddhini
(To:sjuraj)
skvarka juraj,I set my parent dialog SetAlwaysTop equal to True.But when i use this for JOptionPane.showmessageialog it can't load to front ..Don't know how to overcome this.please help me
sjuraj
(To:ddhini)
Try this: java - JOptionPane won't show its dialog on top of other windows - Stack Overflow
But if you need only to display info use session.UIShowMessageDialog instead.
