I want to delete few parts from the Intralink 3.4 system where file names are given in a CSV file. I would like write a Toolkit application in C to delete those files.
But I don't find any development document on this.
I somehow managed to compile the demo program for testing the installation and I could not able to run it. Can anybody share some knowledge on this?
Hi Selvam -
I wish I could be of more help, but I the last time I wrote anything with the Intralink toolkit was over 10 years ago. My own company moved from Intralink to Windchill some 5 or 6 years ago.
Did you receive any error messages when you ran your code? If so, could you post them here?
|+| M a r k |+|
As we're migrating from Pro/I 3.4 to PDMLink 10.2 soon, in the last year I developed a handful Pro/INT Toolkit programs. So I hope, I can help you ...
Ok, compiling a demo application worked for you - you've got a EXE file, you want to run now, right?
Have you installed the Pro/INTRALINK Toolkit Environment somewhere? This is required for running the developed program!
