Visual studio setting for protoolkit
Ketan_Lalcheta
Hello
I have checked two different type of Visual Studio project setting for toolkit project.
I am wondering which one is the best one? Does anyone have come across any document regarding project setting recommended by PTC?
I am using Creo 2.0 M80.
Thanks and Regards
Ketan
There is an example project inside:
<Creo 3.0 Installation Path>\M060\Common Files\protoolkit\x86e_win64\obj\protk_install_example.zip
<Creo 2.0 Installation Path>\Common Files\M120\protoolkit\x86e_win64\obj\protk_install_example.zip
But often an own set up project would do it better in the past. So I don't know how good it is. Also you need to check some properties like debug mode, ... to be sure it's working like you except it.
Br,
Eike
I am getting attached error:Any idea?
Think you forget the mpr.lib
We use the following libs to compile:
ws2_32.lib;wsock32.lib;mpr.lib;netapi32.lib;psapi.lib;protk_dll.lib;otk_cpp.lib;Msimg32.lib;wldap32.lib;%(AdditionalDependencies)
Br,
Eike
