Run mapkey via toolkit
i want to assign the geometry id for measured item by toolkit .
it's possible when i use mapkey ?
Almost everything you can do manually is possible via mapkey. If you want to rename measured item based on geom id then create mapkey and put the id to the mapkey string.
