silent install problem
Dmi3U
Hi All!
I use ptc's silent install practice for my mass deployment scripts. So I install creobase and parametric manually to create the xml files. During the installation I specify c:\ptc directory for all components to be installed in. When this install completes I have C:\PTC folder where there are Creo and Creo 3.0 folders inside. Creo agent is  getting installed under Creo and M050 with all modules are under Creo 3.0. This is what I want!
BUT, when I run it in silent install mode it puts creo agent under c:\Program Files (x86)\Common Files and Thumbviewer and creoview express under c:\Program Files\PTC.
I need all of that to be under c:\ptc. Did anyone run into this? Can you please share if you have a solution?
Thank you in advance!
Dmitry
CREO BASE
setup.exe -translate_lp_path_space"" -xml creobase.p.xml
CREO PARAMETRIC
setup.exe -translate_lp_path_space"" -xml pma.p.xml
CREO SIMULATION
setup.exe -translate_lp_path_space"" -xml sim.p.xml
xml files:
creobase.p
<?xml version="1.0" encoding="utf-8" standalone="no" ?>
<PRODUCT datecode="2015080" family="Creo" name="PTC Creo Common Files" parentonly="Y" shipcode="M040" tag="creobase.xml" version="3.0">
  <PROPERTIES>
    <PROPERTY name="installdir">[PROGRAMFILES]/PTC</PROPERTY>
    <PROPERTY name="cachedir">[APPLICATIONDATA]/PTC Download/[MEDIAID]</PROPERTY>
    <PROPERTY name="[INSTALLBASE]">c:\PTC</PROPERTY>
    <PROPERTY name="[COMMONFILESNAME]">CommonFiles</PROPERTY>
    <PROPERTY name="[CREOCOMMONFILES]">[INSTALLBASE]/Creo3/[SHIPCODE]/[COMMONFILESNAME]</PROPERTY>
    <PROPERTY name="[LP]">[CREOCOMMONFILES]</PROPERTY>
    <PROPERTY name="[OLDSHIPCODE]">OLD</PROPERTY>
    <PROPERTY name="[OLDCREOCOMMONFILES]">[INSTALLBASE]/Creo3/[OLDSHIPCODE]/[COMMONFILESNAME]</PROPERTY>
    <PROPERTY name="[OLDLP]">[OLDCREOCOMMONFILES]</PROPERTY>
    <PROPERTY name="[Update MOR PATH]">[INSTALLBASE]/Creo3/[OLDSHIPCODE]</PROPERTY>
    <PROPERTY name="latestSideUpdate">true</PROPERTY>
      <PROPERTY name="[ICON]">[LP]/[THIS_ARCH]/obj/creologo.ico</PROPERTY>
      <PROPERTY name="[OpenWith]">Open With a Creo App</PROPERTY>
    <PROPERTY name="CustomActions">true</PROPERTY>
    <PROPERTY name="NoUninstallEntry"/>
    <PROPERTY name="NoLPInstaller"/>
    <PROPERTY name="NoServices"/>
    <PROPERTY name="NoShortcuts"/>
    <PROPERTY name="NoPSF"/>
       <PROPERTY msgid="145002781" name="ToolTip">pimToolTipComFiles</PROPERTY>
    <PROPERTY name="[PROGRAMFILES]">C:\Program Files</PROPERTY>
    <PROPERTY name="[PROGRAMFILESx86]">C:\Program Files (x86)</PROPERTY>
    <PROPERTY name="[APPLICATIONDATA]">C:\Users\u1dx_hs\AppData\Roaming</PROPERTY>
    <PROPERTY name="[APPLICATIONDATA_ALLUSERS]">C:\ProgramData</PROPERTY>
    <PROPERTY name="[DOCUMENTS_ALLUSERS]">C:\Users\Public\Documents</PROPERTY>
    <PROPERTY name="[VERSION]">3.0</PROPERTY>
    <PROPERTY name="[SHIPCODE]">M040</PROPERTY>
    <PROPERTY name="NoDownloadSupport">use_image</PROPERTY>
    <PROPERTY name="[SOURCE]">c:\PTC\CREO3_M040_Win64</PROPERTY>
    <PROPERTY name="localhost.msi.version">5.0</PROPERTY>
    <PROPERTY install="Y" name="InstallMe"/>
    <PROPERTY name="UI_started">Y</PROPERTY>
    <PROPERTY name="status_message">Wird installiert...</PROPERTY>
  </PROPERTIES>
  <!-- Distribution could be local disk, web, or in the future maybe ftp? -->
  <DISTRIBUTION from="">
    <LANGUAGES>
      <LANGUAGE install="Y" installed="N" name="usascii" required="Y">Englisch</LANGUAGE>
      <LANGUAGE install="N" installed="N" name="french">Französisch</LANGUAGE>
      <LANGUAGE install="Y" installed="N" name="german">Deutsch</LANGUAGE>
      <LANGUAGE install="N" installed="N" name="italian">Italienisch</LANGUAGE>
      <LANGUAGE install="N" installed="N" name="spanish">Spanisch</LANGUAGE>
      <LANGUAGE install="N" installed="N" name="japanese">Japanisch</LANGUAGE>
      <LANGUAGE install="N" installed="N" name="korean">Koreanisch</LANGUAGE>
      <LANGUAGE install="Y" installed="N" name="chinese_cn">Vereinfachtes Chinesisch</LANGUAGE>
      <LANGUAGE install="N" installed="N" name="chinese_tw">Traditionelles Chinesisch</LANGUAGE>
      <LANGUAGE install="N" installed="N" name="russian">Russisch</LANGUAGE>
    </LANGUAGES>
    <PLATFORMS>
      <PLATFORM install="Y" installed="N" name="x86e_win64">Windows 64-Bit</PLATFORM>
    </PLATFORMS>
    <PACKAGES>
      <PACKAGE hidden="N" install="Y" installed="N" label="Creo Gemeinsame Dateien" name="creo_base" parent="" required="Y">
        <FEATURE>creo_text_tree</FEATURE>
        <FEATURE>creo_text_tree_piping</FEATURE>
        <FEATURE>creo_text_misc</FEATURE>
        <FEATURE>creo_uitools_res</FEATURE>
        <FEATURE>creo_res</FEATURE>
        <FEATURE>creo_pv</FEATURE>
        <FEATURE>creo_cetol</FEATURE>
        <FEATURE>creo_nms</FEATURE>
        <FEATURE>creo_gplugs</FEATURE>
        <FEATURE>creo_symbols</FEATURE>
        <FEATURE>creo_lib</FEATURE>
        <FEATURE>creo_obj</FEATURE>
        <FEATURE>creo_obj_extensions</FEATURE>
        <FEATURE>creo_mdl_templates</FEATURE>
        <FEATURE>creo_graphic_lib</FEATURE>
        <FEATURE>creo_manikin_lite</FEATURE>
        <FEATURE>creo_landing</FEATURE>
        <FEATURE>dsq</FEATURE>
        <FEATURE>dbatchs</FEATURE>
        <FEATURE>flexclient</FEATURE>
        <FEATURE>iculibs</FEATURE>
        <FEATURE>Mozilla</FEATURE>
        <FEATURE>introfiles</FEATURE>
        <FEATURE>pro_from_cptr</FEATURE>
        <FEATURE>pro_to_cat</FEATURE>
        <FEATURE>pro_from_feas</FEATURE>
        <FEATURE>procgi</FEATURE>
        <FEATURE>Demos</FEATURE>
        <FEATURE>proappt</FEATURE>
        <FEATURE>ncexpert</FEATURE>
        <FEATURE>weld_data</FEATURE>
        <FEATURE>mechanism</FEATURE>
        <FEATURE>animation</FEATURE>
        <FEATURE>creo_harness_mfg</FEATURE>
        <!-- install/addons MSI file -->
        <FEATURE>creoagent</FEATURE>
        <FEATURE>thumbviewer</FEATURE>
        <FEATURE>cevexpress</FEATURE>
        <SCRIPT dest="[LP]/i486_nt/obj/system_monitor.bat" name="system_monitor" platform="i486_nt" source="creo_templates.xml"/>
        <SCRIPT dest="[LP]/x86e_win64/obj/system_monitor.bat" installed="Y" name="system_monitor" platform="x86e_win64" source="creo_templates.xml"/>
      </PACKAGE>
    </PACKAGES>
    <CDSECTION install="Y" installed="Y" name="procgi" platform="x86e_win64" size="3148288">ptc0.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="pro_from_feas" platform="x86e_win64" size="8364616">ptc1.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="pro_from_cptr" platform="x86e_win64" size="15027712">ptc2.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="creo_text_tree" size="102247431">ptc12.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" language="chinese_cn" name="creo_text_tree" size="24864055">ptc13.cab</CDSECTION>
    <CDSECTION install="N" language="chinese_tw" name="creo_text_tree" size="36728548">ptc14.cab</CDSECTION>
    <CDSECTION install="N" language="korean" name="creo_text_tree" size="1553966">ptc15.cab</CDSECTION>
    <CDSECTION install="N" language="japanese" name="creo_text_tree" size="1877074">ptc16.cab</CDSECTION>
    <CDSECTION install="N" language="russian" name="creo_text_tree" size="79781">ptc17.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="creo_text_tree_piping" size="14775182">ptc18.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="creo_text_misc" size="6447962">ptc19.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" language="chinese_cn" name="creo_text_misc" size="1743271">ptc20.cab</CDSECTION>
    <CDSECTION install="N" language="chinese_tw" name="creo_text_misc" size="1745975">ptc21.cab</CDSECTION>
    <CDSECTION install="N" language="russian" name="creo_text_misc" size="1745835">ptc22.cab</CDSECTION>
    <CDSECTION install="N" language="korean" name="creo_text_misc" size="1753482">ptc23.cab</CDSECTION>
    <CDSECTION install="N" language="japanese" name="creo_text_misc" size="1763311">ptc24.cab</CDSECTION>
    <CDSECTION install="N" language="french" name="creo_text_misc" size="1764747">ptc25.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" language="german" name="creo_text_misc" size="1759646">ptc26.cab</CDSECTION>
    <CDSECTION install="N" language="italian" name="creo_text_misc" size="1757862">ptc27.cab</CDSECTION>
    <CDSECTION install="N" language="spanish" name="creo_text_misc" size="1760718">ptc28.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="Demos" size="1338472">ptc29.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="proappt" size="62642">ptc30.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="ncexpert" size="1689497">ptc31.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="creo_uitools_res" size="6119376">ptc32.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" language="chinese_cn" name="creo_uitools_res" size="930640">ptc33.cab</CDSECTION>
    <CDSECTION install="N" language="chinese_tw" name="creo_uitools_res" size="907741">ptc34.cab</CDSECTION>
    <CDSECTION install="N" language="russian" name="creo_uitools_res" size="972926">ptc35.cab</CDSECTION>
    <CDSECTION install="N" language="korean" name="creo_uitools_res" size="943940">ptc36.cab</CDSECTION>
    <CDSECTION install="N" language="japanese" name="creo_uitools_res" size="991066">ptc37.cab</CDSECTION>
    <CDSECTION install="N" language="french" name="creo_uitools_res" size="979014">ptc38.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" language="german" name="creo_uitools_res" size="983149">ptc39.cab</CDSECTION>
    <CDSECTION install="N" language="italian" name="creo_uitools_res" size="977731">ptc40.cab</CDSECTION>
    <CDSECTION install="N" language="spanish" name="creo_uitools_res" size="989995">ptc41.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="creo_res" size="70765667">ptc42.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" language="chinese_cn" name="creo_res" size="21956053">ptc43.cab</CDSECTION>
    <CDSECTION install="N" language="chinese_tw" name="creo_res" size="27592078">ptc44.cab</CDSECTION>
    <CDSECTION install="N" language="russian" name="creo_res" size="23368749">ptc45.cab</CDSECTION>
    <CDSECTION install="N" language="korean" name="creo_res" size="18363336">ptc46.cab</CDSECTION>
    <CDSECTION install="N" language="japanese" name="creo_res" size="19807218">ptc47.cab</CDSECTION>
    <CDSECTION install="N" language="french" name="creo_res" size="18812851">ptc48.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" language="german" name="creo_res" size="18079770">ptc49.cab</CDSECTION>
    <CDSECTION install="N" language="italian" name="creo_res" size="18008404">ptc50.cab</CDSECTION>
    <CDSECTION install="N" language="spanish" name="creo_res" size="18521805">ptc51.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="creo_res" platform="x86e_win64" size="3856380">ptc52.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" language="chinese_cn" name="creo_res" platform="x86e_win64" size="8758589">ptc53.cab</CDSECTION>
    <CDSECTION install="N" language="chinese_tw" name="creo_res" platform="x86e_win64" size="11704618">ptc54.cab</CDSECTION>
    <CDSECTION install="N" language="russian" name="creo_res" platform="x86e_win64" size="4084898">ptc55.cab</CDSECTION>
    <CDSECTION install="N" language="korean" name="creo_res" platform="x86e_win64" size="3528534">ptc56.cab</CDSECTION>
    <CDSECTION install="N" language="japanese" name="creo_res" platform="x86e_win64" size="3613072">ptc57.cab</CDSECTION>
    <CDSECTION install="N" language="french" name="creo_res" platform="x86e_win64" size="4254492">ptc58.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" language="german" name="creo_res" platform="x86e_win64" size="4108034">ptc59.cab</CDSECTION>
    <CDSECTION install="N" language="italian" name="creo_res" platform="x86e_win64" size="4230098">ptc60.cab</CDSECTION>
    <CDSECTION install="N" language="spanish" name="creo_res" platform="x86e_win64" size="4330750">ptc61.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="creo_pv" size="3733093">ptc62.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="creo_pv" platform="x86e_win64" size="66063744">ptc63.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="creo_cetol" platform="x86e_win64" size="158502">ptc64.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" language="chinese_cn" name="creo_cetol" platform="x86e_win64" size="22998">ptc65.cab</CDSECTION>
    <CDSECTION install="N" language="chinese_tw" name="creo_cetol" platform="x86e_win64" size="22972">ptc66.cab</CDSECTION>
    <CDSECTION install="N" language="french" name="creo_cetol" platform="x86e_win64" size="27209">ptc67.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" language="german" name="creo_cetol" platform="x86e_win64" size="26502">ptc68.cab</CDSECTION>
    <CDSECTION install="N" language="italian" name="creo_cetol" platform="x86e_win64" size="26431">ptc69.cab</CDSECTION>
    <CDSECTION install="N" language="japanese" name="creo_cetol" platform="x86e_win64" size="25525">ptc70.cab</CDSECTION>
    <CDSECTION install="N" language="korean" name="creo_cetol" platform="x86e_win64" size="24409">ptc71.cab</CDSECTION>
    <CDSECTION install="N" language="spanish" name="creo_cetol" platform="x86e_win64" size="27267">ptc72.cab</CDSECTION>
    <CDSECTION install="N" language="russian" name="creo_cetol" platform="x86e_win64" size="31363">ptc73.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="creo_nms" platform="x86e_win64" size="24425984">ptc74.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="creo_lib" platform="x86e_win64" size="694823710">ptc75.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="creo_obj" platform="x86e_win64" size="894296643">ptc76.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="creo_obj_extensions" platform="x86e_win64" size="208095265">ptc78.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="creo_mdl_templates" size="11700187">ptc98.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="creo_graphic_lib" size="116316729">ptc100.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="creo_manikin_lite" size="16635200">ptc101.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="creo_symbols" size="1935727">ptc102.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="flexclient" size="48086">ptc106.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="flexclient" platform="x86e_win64" size="8234248">ptc107.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="weld_data" size="37027">ptc109.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="mechanism" size="1358020">ptc124.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" language="chinese_cn" name="mechanism" size="1068498">ptc125.cab</CDSECTION>
    <CDSECTION install="N" language="chinese_tw" name="mechanism" size="1175758">ptc126.cab</CDSECTION>
    <CDSECTION install="N" language="french" name="mechanism" size="1388037">ptc127.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" language="german" name="mechanism" size="1324529">ptc128.cab</CDSECTION>
    <CDSECTION install="N" language="italian" name="mechanism" size="1208455">ptc129.cab</CDSECTION>
    <CDSECTION install="N" language="japanese" name="mechanism" size="1446912">ptc130.cab</CDSECTION>
    <CDSECTION install="N" language="korean" name="mechanism" size="1211519">ptc131.cab</CDSECTION>
    <CDSECTION install="N" language="russian" name="mechanism" size="1947772">ptc132.cab</CDSECTION>
    <CDSECTION install="N" language="spanish" name="mechanism" size="1216875">ptc133.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="mechanism" platform="x86e_win64" size="24791166">ptc134.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="animation" size="1386979">ptc135.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" language="chinese_cn" name="animation" size="1108938">ptc136.cab</CDSECTION>
    <CDSECTION install="N" language="chinese_tw" name="animation" size="1216319">ptc137.cab</CDSECTION>
    <CDSECTION install="N" language="french" name="animation" size="1431747">ptc138.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" language="german" name="animation" size="1367263">ptc139.cab</CDSECTION>
    <CDSECTION install="N" language="italian" name="animation" size="1251357">ptc140.cab</CDSECTION>
    <CDSECTION install="N" language="japanese" name="animation" size="1492990">ptc141.cab</CDSECTION>
    <CDSECTION install="N" language="korean" name="animation" size="1254989">ptc142.cab</CDSECTION>
    <CDSECTION install="N" language="russian" name="animation" size="1996615">ptc143.cab</CDSECTION>
    <CDSECTION install="N" language="spanish" name="animation" size="1260184">ptc144.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="animation" platform="x86e_win64" size="26222062">ptc145.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="dsq" size="2381391">ptc168.cab</CDSECTION>
    <CDSECTION install="N" language="russian" name="dsq" size="156541">ptc172.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" language="chinese_cn" name="dsq" size="129179">ptc173.cab</CDSECTION>
    <CDSECTION install="N" language="chinese_tw" name="dsq" size="128626">ptc175.cab</CDSECTION>
    <CDSECTION install="N" language="french" name="dsq" size="139701">ptc177.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" language="german" name="dsq" size="135819">ptc179.cab</CDSECTION>
    <CDSECTION install="N" language="italian" name="dsq" size="135420">ptc181.cab</CDSECTION>
    <CDSECTION install="N" language="japanese" name="dsq" size="144161">ptc183.cab</CDSECTION>
    <CDSECTION install="N" language="korean" name="dsq" size="134754">ptc185.cab</CDSECTION>
    <CDSECTION install="N" language="spanish" name="dsq" size="138293">ptc187.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="dsq" platform="x86e_win64" size="46415520">ptc206.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="dbatchs" platform="x86e_win64" size="17294336">ptc207.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="creo_landing" size="34487020">ptc224.cab</CDSECTION>
    <CDSECTION install="N" language="french" name="creo_landing" size="31831665">ptc225.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" language="german" name="creo_landing" size="30263007">ptc226.cab</CDSECTION>
    <CDSECTION install="N" language="italian" name="creo_landing" size="30260365">ptc227.cab</CDSECTION>
    <CDSECTION install="N" language="spanish" name="creo_landing" size="30899657">ptc228.cab</CDSECTION>
    <CDSECTION install="N" language="japanese" name="creo_landing" size="32239207">ptc229.cab</CDSECTION>
    <CDSECTION install="N" language="korean" name="creo_landing" size="35101459">ptc230.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" language="chinese_cn" name="creo_landing" size="30291264">ptc231.cab</CDSECTION>
    <CDSECTION install="N" language="chinese_tw" name="creo_landing" size="33984794">ptc232.cab</CDSECTION>
    <CDSECTION install="N" language="russian" name="creo_landing" size="34462558">ptc233.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="creoagent" size="4458">ptc265.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="iculibs" platform="x86e_win64" size="45064192">ptc270.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="creo_harness_mfg" size="27748153">ptc281.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" language="chinese_cn" name="creo_harness_mfg" size="14864">ptc282.cab</CDSECTION>
    <CDSECTION install="N" language="chinese_tw" name="creo_harness_mfg" size="14975">ptc283.cab</CDSECTION>
    <CDSECTION install="N" language="french" name="creo_harness_mfg" size="16726">ptc284.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" language="german" name="creo_harness_mfg" size="16613">ptc285.cab</CDSECTION>
    <CDSECTION install="N" language="italian" name="creo_harness_mfg" size="16872">ptc286.cab</CDSECTION>
    <CDSECTION install="N" language="japanese" name="creo_harness_mfg" size="18213">ptc287.cab</CDSECTION>
    <CDSECTION install="N" language="korean" name="creo_harness_mfg" size="11303">ptc288.cab</CDSECTION>
    <CDSECTION install="N" language="spanish" name="creo_harness_mfg" size="16907">ptc289.cab</CDSECTION>
    <CDSECTION install="N" language="russian" name="creo_harness_mfg" size="21799">ptc290.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="creo_harness_mfg" platform="x86e_win64" size="27769856">ptc292.cab</CDSECTION>
  </DISTRIBUTION>
  <REGISTRY>
    <VALUE default="phwFile" id=".phw" installed="Y" key="[HKCR]"/>
      <VALUE default="PTC Helper App File" id="phwFile" installed="Y" key="[HKCR]"/>
    <VALUE default="[ICON],0" id="DefaultIcon" installed="Y" key="[HKCR]phwFile"/>
    <VALUE default="" id="Shell" installed="Y" key="[HKCR]phwFile"/>
    <VALUE default="[OpenWith]" id="Open" installed="Y" key="[HKCR]phwFile/Shell"/>
    <VALUE default="&quot;[LP]/[THIS_ARCH]/obj/creo_openwith.exe&quot; &quot;%1&quot;" id="Command" installed="Y" key="[HKCR]phwFile/Shell/Open"/>
  </REGISTRY>
  <CUSTOM_ACTION dest="[LP]/text/config.pro" dll="" location="[CREOCOMMONFILES]" name="BackupFile" when="PreInstall"/>
  <CUSTOM_ACTION dest="[LP]/text/config.sup" dll="" location="[CREOCOMMONFILES]" name="BackupFile" when="PreInstall"/>
  <CUSTOM_ACTION dest="[LP]/text/config.win" dll="" location="[CREOCOMMONFILES]" name="BackupFile" when="PreInstall"/>
  <CUSTOM_ACTION dest="[LP]/text/menu_def.pro" dll="" location="[CREOCOMMONFILES]" name="BackupFile" when="PreInstall"/>
  <CUSTOM_ACTION dest="[LP]/text/protk.dat" dll="" location="[CREOCOMMONFILES]" name="BackupFile" when="PreInstall"/>
  <CUSTOM_ACTION dest="[LP]/text/config.abz" dll="" location="[CREOCOMMONFILES]" name="BackupFile" when="PreInstall"/>
  <CUSTOM_ACTION dest="[LP]/text/creo_direct_admin_customization.ui" dll="" location="[CREOCOMMONFILES]" name="BackupFile" when="PreInstall"/>
  <CUSTOM_ACTION dest="[LP]/text/creo_optm_admin_customization.ui" dll="" location="[CREOCOMMONFILES]" name="BackupFile" when="PreInstall"/>
  <CUSTOM_ACTION dest="[LP]/text/creo_parametric_admin_customization.ui" dll="" location="[CREOCOMMONFILES]" name="BackupFile" when="PreInstall"/>
  <CUSTOM_ACTION dest="[LP]/text/creo_layout_admin_customization.ui" dll="" location="[CREOCOMMONFILES]" name="BackupFile" when="PreInstall"/>
  <CUSTOM_ACTION dest="[LP]/text/creo_simulate_admin_customization.ui" dll="" location="[CREOCOMMONFILES]" name="BackupFile" when="PreInstall"/>
  <CUSTOM_ACTION dest="[LP]/text/config.pro" dll="" location="[OLDCREOCOMMONFILES]" name="RestoreBackup" when="PostInstall"/>
  <CUSTOM_ACTION dest="[LP]/text/config.sup" dll="" location="[OLDCREOCOMMONFILES]" name="RestoreBackup" when="PostInstall"/>
  <CUSTOM_ACTION dest="[LP]/text/config.win" dll="" location="[OLDCREOCOMMONFILES]" name="RestoreBackup" when="PostInstall"/>
  <CUSTOM_ACTION dest="[LP]/text/menu_def.pro" dll="" location="[OLDCREOCOMMONFILES]" name="RestoreBackup" when="PostInstall"/>
  <CUSTOM_ACTION dest="[LP]/text/protk.dat" dll="" location="[OLDCREOCOMMONFILES]" name="RestoreBackup" when="PostInstall"/>
  <CUSTOM_ACTION dest="[LP]/text/config.abz" dll="" location="[OLDCREOCOMMONFILES]" name="RestoreBackup" when="PostInstall"/>
  <CUSTOM_ACTION dest="[LP]/text/creo_direct_admin_customization.ui" dll="" location="[OLDCREOCOMMONFILES]" name="RestoreBackup" when="PostInstall"/>
  <CUSTOM_ACTION dest="[LP]/text/creo_optm_admin_customization.ui" dll="" location="[OLDCREOCOMMONFILES]" name="RestoreBackup" when="PostInstall"/>
  <CUSTOM_ACTION dest="[LP]/text/creo_parametric_admin_customization.ui" dll="" location="[OLDCREOCOMMONFILES]" name="RestoreBackup" when="PostInstall"/>
  <CUSTOM_ACTION dest="[LP]/text/creo_layout_admin_customization.ui" dll="" location="[OLDCREOCOMMONFILES]" name="RestoreBackup" when="PostInstall"/>
  <CUSTOM_ACTION dest="[LP]/text/creo_simulate_admin_customization.ui" dll="" location="[OLDCREOCOMMONFILES]" name="RestoreBackup" when="PostInstall"/>
  <CUSTOM_ACTION dest="[LP]/install/addon/creoagent_32.msi" dll="" name="SetFilePermissions" perm="RX" when="PostInstall"/>
  <CUSTOM_ACTION dest="[LP]/install/addon/creoagent_32_64.msi" dll="" name="SetFilePermissions" perm="RX" when="PostInstall"/>
  <CUSTOM_ACTION dest="[LP]/install/addon/Thumbviewer_32.msi" dll="" name="SetFilePermissions" perm="RX" when="PostInstall"/>
  <CUSTOM_ACTION dest="[LP]/install/addon/Thumbviewer_32_64.msi" dll="" name="SetFilePermissions" perm="RX" when="PostInstall"/>
  <CUSTOM_ACTION dest="[LP]/install/addon/pvx32/CreoSetup.exe" dll="" name="SetFilePermissions" perm="RX" when="PostInstall"/>
  <CUSTOM_ACTION dest="[LP]/install/addon/pvx32_64/CreoSetup.exe" dll="" name="SetFilePermissions" perm="RX" when="PostInstall"/>
</PRODUCT>
pma.p:
<!-- 06-Apr-12 P-20-03 TWH      add wfc_cppwiz -->
<PRODUCT datecode="2015080" family="Creo" name="PTC Creo Parametric" parent="creobase.xml" shipcode="M040" tag="pma.xml" version="3.0">
  <PROPERTIES>
    <PROPERTY name="ltr_prefix">CREOPMA PROE</PROPERTY>
    <PROPERTY name="RegEdit1To250">true</PROPERTY>
    <PROPERTY name="ARPURLUpdateInfo">https://www.ptc.com/cgi/cs/apps/SftUpd/SftUpdProd.pl</PROPERTY>
    <PROPERTY name="ARPURLInfoAbout">http://www.ptc.com/product/creo/parametric</PROPERTY>
    <PROPERTY name="[LP]">[INSTALLBASE]/Creo3/[SHIPCODE]/Parametric</PROPERTY>
    <PROPERTY name="[OpenWith]">Mit PTC Creo Parametric öffnen</PROPERTY>
    <PROPERTY name="[ICON]">[LP]/install/nt/parametric.ico</PROPERTY>
    <PROPERTY name="[OLDLP]">[INSTALLBASE]/Creo3/[OLDSHIPCODE]/Parametric</PROPERTY>
       <PROPERTY msgid="145002786" name="ToolTip">pimToolTipPMA</PROPERTY>
       <PROPERTY name="invoke_phm_exe">[LP]/bin/parametric.exe</PROPERTY>
  </PROPERTIES>
  <PREREQUISITE required="Y">creoplatformagent.xml</PREREQUISITE>
    <LANGUAGES>
    </LANGUAGES>
    <PLATFORMS>
    </PLATFORMS>
    <PACKAGES>
      <PACKAGE hidden="N" install="Y" label="PTC Creo Parametric" name="pma_base" parent="" required="Y">
        <FEATURE>applstart</FEATURE>
        <FEATURE>pma_applstart</FEATURE>
        <FEATURE>cocsim_applstart</FEATURE>
        <FEATURE>Install</FEATURE>
        <FEATURE>swim</FEATURE>
        <FEATURE location="[CREOCOMMONFILES]">creo_lib_extensions</FEATURE>
             <FEATURE location="[CREOCOMMONFILES]">creocalc_files</FEATURE>
        <SCRIPT dest="[LP]/bin/ptchostid.bat" installed="Y" name="ptchostid" source="creo_templates.xml"/>
        <SCRIPT dest="[LP]/bin/ptcflush.bat" installed="Y" name="ptcflush" source="creo_templates.xml"/>
        <SCRIPT dest="[LP]/bin/ptcstatus.bat" installed="Y" name="ptcstatus" source="creo_templates.xml"/>
        <SCRIPT dest="[LP]/bin/convert_image.bat" installed="Y" name="convert_image" source="creo_templates.xml"/>
        <SCRIPT dest="[LP]/bin/dcadsetup.bat" installed="Y" name="dcadsetup" source="creo_templates.xml"/>
        <SCRIPT dest="[LP]/bin/dcadshutdown.bat" installed="Y" name="dcadshutdown" source="creo_templates.xml"/>
        <SCRIPT dest="[LP]/bin/parametric_borrow.bat" installed="Y" name="parametric_borrow" source="creo_templates.xml"/>
        <SCRIPT dest="[LP]/bin/pro_mcs_comp.bat" installed="Y" name="pro_mcs_comp" source="creo_templates.xml"/>
        <SCRIPT dest="[LP]/bin/pro_ncl_cvt.bat" installed="Y" name="pro_ncl_cvt" source="creo_templates.xml"/>
        <SCRIPT dest="[LP]/bin/procvter.bat" name="procvter" source="creo_templates.xml"/>
        <SCRIPT dest="[LP]/bin/procvtutil.bat" installed="Y" name="procvtutil" source="creo_templates.xml"/>
        <SCRIPT dest="[LP]/bin/proigsutil.bat" name="proigsutil" source="creo_templates.xml"/>
        <SCRIPT dest="[LP]/bin/propostg.bat" installed="Y" name="propostg" source="creo_templates.xml"/>
        <SCRIPT dest="[LP]/bin/propostl.bat" installed="Y" name="propostl" source="creo_templates.xml"/>
        <SCRIPT dest="[LP]/bin/propostq.bat" installed="Y" name="propostq" source="creo_templates.xml"/>
        <SCRIPT dest="[LP]/bin/protab.bat" installed="Y" name="protab" source="creo_templates.xml"/>
        <SCRIPT dest="[LP]/bin/protk_unlock.bat" installed="Y" name="protk_unlock" source="creo_templates.xml"/>
        <SCRIPT dest="[LP]/bin/ptcborrow.bat" installed="Y" name="ptcborrow" source="creo_templates.xml"/>
        <SCRIPT dest="[LP]/bin/purge.bat" installed="Y" name="purge" source="creo_templates.xml"/>
        <SCRIPT dest="[LP]/bin/showmip.bat" name="showmip" source="creo_templates.xml"/>
        <SCRIPT dest="[LP]/bin/tempmgr.bat" name="tempmgr" source="creo_templates.xml"/>
      </PACKAGE>
      <PACKAGE hidden="N" install="N" label="Optionen" name="creooptions" parent="" required="N"/>
      <PACKAGE hidden="N" install="N" label="API-Toolkits" name="api_toolkits" parent="" required="N"/>
      <PACKAGE hidden="N" install="N" label="Schnittstellen" name="interfaces" parent="" required="N"/>
      <PACKAGE hidden="N" install="Y" label="PTC Creo Modelcheck" name="modelcheck" parent="creooptions" required="N">
        <FEATURE location="[CREOCOMMONFILES]">ModelCHECK</FEATURE>
        <SCRIPT dest="[LP]/bin/modelcheck.bat" installed="Y" name="modelcheck" source="creo_templates.xml"/>
        <ENABLE_SHORTCUT id="modchk_shortcut"/>
      </PACKAGE>
      <PACKAGE hidden="Y" install="N" label="School Edition config files" name="school_package" parent="creooptions" required="Y">
        <FEATURE location="[CREOCOMMONFILES]">school_config</FEATURE>
      </PACKAGE>
      <PACKAGE hidden="Y" install="Y" label="PTC Creo Parametric Advanced Framework Extension" name="afx" parent="creooptions" required="Y">
        <FEATURE location="[CREOCOMMONFILES]">efx</FEATURE>
        <FEATURE location="[CREOCOMMONFILES]">EFX Tree</FEATURE>
        <FEATURE location="[CREOCOMMONFILES]">efxhelp</FEATURE>
      </PACKAGE>
      <PACKAGE hidden="N" install="N" label="JRE" name="j2re" parent="creooptions" required="N">
        <FEATURE location="[CREOCOMMONFILES]">jre</FEATURE>
      </PACKAGE>
      <PACKAGE hidden="N" install="N" label="Spritzgusskomponenten-Katalog" name="moldcat" parent="creooptions" required="N">
        <FEATURE location="[CREOCOMMONFILES]">apps_data</FEATURE>
      </PACKAGE>
         <PACKAGE hidden="N" install="Y" label="PTC Creo Mold Analysis" name="creocma" parent="creooptions" required="N">
        <FEATURE location="[CREOCOMMONFILES]">cma_files</FEATURE>
       </PACKAGE>
      <PACKAGE hidden="N" install="Y" label="NC-GPOST" name="gpost" parent="creooptions" required="N">
        <FEATURE location="[CREOCOMMONFILES]">gpost</FEATURE>
        <SCRIPT dest="[LP]/bin/progpostg.bat" installed="Y" name="progpostg" source="creo_templates.xml"/>
        <SCRIPT dest="[LP]/bin/progpostl.bat" installed="Y" name="progpostl" source="creo_templates.xml"/>
        <SCRIPT dest="[LP]/bin/progpostq.bat" installed="Y" name="progpostq" source="creo_templates.xml"/>
      </PACKAGE>
      <PACKAGE hidden="N" install="N" label="VERICUT (R)" name="vericut" parent="creooptions" required="N">
        <FEATURE location="[CREOCOMMONFILES]">vericut</FEATURE>
        <SCRIPT dest="[LP]/bin/proems.bat" name="proems" source="creo_templates.xml"/>
        <SCRIPT dest="[LP]/bin/proev.bat" name="proev" source="creo_templates.xml"/>
      </PACKAGE>
      <PACKAGE hidden="N" install="N" label="PTC Creo Parametric Distributed Computing Extension" name="dbatchc" parent="creooptions" required="N">
        <FEATURE location="[CREOCOMMONFILES]">dbatchc</FEATURE>
        <FEATURE location="[CREOCOMMONFILES]">uitools_res</FEATURE>
        <FEATURE location="[CREOCOMMONFILES]">fileopensaveas</FEATURE>
        <FEATURE location="[CREOCOMMONFILES]">dbatchchelp</FEATURE>
        <SCRIPT dest="[LP]/bin/ptcdbatch.bat" name="ptcdbatch" source="creo_templates.xml"/>
        <ENABLE_SHORTCUT id="dbatchc_shortcut"/>
      </PACKAGE>
      <PACKAGE hidden="N" install="Y" label="J-Link für PTC Creo Parametric" name="pro_java" parent="api_toolkits" required="N">
        <FEATURE location="[CREOCOMMONFILES]">java</FEATURE>
        <FEATURE location="[CREOCOMMONFILES]">jlinkwiz</FEATURE>
      </PACKAGE>
      <PACKAGE hidden="N" install="Y" label="Web.Link für PTC Creo Parametric" name="weblink" parent="api_toolkits" required="N">
        <FEATURE location="[CREOCOMMONFILES]">weblink</FEATURE>
        <FEATURE location="[CREOCOMMONFILES]">weblinkplugins</FEATURE>
        <FEATURE location="[CREOCOMMONFILES]">pfcweblinkwiz</FEATURE>
        <FEATURE location="[CREOCOMMONFILES]">weblinkwiz</FEATURE>
      </PACKAGE>
      <PACKAGE hidden="N" install="N" label="VB API für PTC Creo Parametric" name="vbapi" parent="api_toolkits" required="N">
        <FEATURE location="[CREOCOMMONFILES]">pfcvb</FEATURE>
        <FEATURE location="[CREOCOMMONFILES]">pfcvbwiz</FEATURE>
        <SCRIPT dest="[LP]/bin/vb_api_register.bat" name="vb_api_register" source="creo_templates.xml"/>
        <SCRIPT dest="[LP]/bin/vb_api_unregister.bat" name="vb_api_unregister" source="creo_templates.xml"/>
      </PACKAGE>
      <PACKAGE hidden="N" install="N" label="PTC Creo Parametric Toolkit" name="protoolkit" parent="api_toolkits" required="N">
        <FEATURE location="[CREOCOMMONFILES]">protoolkit</FEATURE>
        <FEATURE location="[CREOCOMMONFILES]">protoolkit_non_levela</FEATURE>
        <FEATURE location="[CREOCOMMONFILES]">protkwiz</FEATURE>
        <SCRIPT dest="[LP]/bin/prodialog_view.bat" name="prodialog_view" source="creo_templates.xml"/>
      </PACKAGE>
      <PACKAGE hidden="N" install="N" label="PTC Creo Object Toolkit C++" name="otk" parent="api_toolkits" required="N">
        <FEATURE location="[CREOCOMMONFILES]">otk_cpp</FEATURE>
        <FEATURE location="[CREOCOMMONFILES]">otk_cpp_doc</FEATURE>
        <FEATURE location="[CREOCOMMONFILES]">otk_cpp_docwiz</FEATURE>
      </PACKAGE>
      <PACKAGE hidden="N" install="N" label="Java Objekt-Toolkit" name="jotk" parent="api_toolkits" required="N">
        <FEATURE location="[CREOCOMMONFILES]">otk_java</FEATURE>
        <FEATURE location="[CREOCOMMONFILES]">otk_java_doc</FEATURE>
        <FEATURE location="[CREOCOMMONFILES]">otk_java_docwiz</FEATURE>
      </PACKAGE>
      <PACKAGE hidden="N" install="N" label="Creo UI Editor" name="uieditor" parent="api_toolkits" required="N">
        <FEATURE location="[CREOCOMMONFILES]">creo_ui_editor</FEATURE>
        <SCRIPT dest="[CREOCOMMONFILES]/creo_ui_editor/bin/creo_ui_editor.bat" name="creo_ui_editor" source="creo_templates.xml"/>
              <ENABLE_SHORTCUT id="ui_editor_shortcut"/>
      </PACKAGE>
      <PACKAGE hidden="N" install="N" label="PTC Creo Parametric Schnittstelle für CADDS 5" name="cadds5" parent="interfaces" required="N">
        <FEATURE location="[CREOCOMMONFILES]">cadds5</FEATURE>
      </PACKAGE>
      <PACKAGE hidden="N" install="Y" label="PTC Creo Parametric Schnittstelle für JT" name="intfjt" parent="interfaces" required="N">
        <FEATURE location="[CREOCOMMONFILES]">intf_jt</FEATURE>
      </PACKAGE>
      <PACKAGE hidden="N" install="Y" label="Direct Modeling Konvertierer" name="coch" parent="interfaces" required="N">
        <FEATURE location="[CREOCOMMONFILES]">cocreateheadless</FEATURE>
      </PACKAGE>
    </PACKAGES>
    <CDSECTION install="Y" installed="Y" location="[CREOCOMMONFILES]" name="creo_lib_extensions" platform="x86e_win64" size="26582528">ptc77.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="pma_applstart" platform="x86e_win64" size="25296896">ptc79.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="cocsim_applstart" platform="x86e_win64" size="25296384">ptc82.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="Install" size="208984">ptc87.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="applstart" size="3705">ptc88.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" language="chinese_cn" name="applstart" size="3490">ptc89.cab</CDSECTION>
    <CDSECTION install="N" language="chinese_tw" name="applstart" size="3505">ptc90.cab</CDSECTION>
    <CDSECTION install="N" language="french" name="applstart" size="4339">ptc91.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" language="german" name="applstart" size="3655">ptc92.cab</CDSECTION>
    <CDSECTION install="N" language="italian" name="applstart" size="3643">ptc93.cab</CDSECTION>
    <CDSECTION install="N" language="japanese" name="applstart" size="4492">ptc94.cab</CDSECTION>
    <CDSECTION install="N" language="korean" name="applstart" size="3660">ptc95.cab</CDSECTION>
    <CDSECTION install="N" language="spanish" name="applstart" size="4294">ptc96.cab</CDSECTION>
    <CDSECTION install="N" language="russian" name="applstart" size="4724">ptc97.cab</CDSECTION>
    <CDSECTION install="N" location="[CREOCOMMONFILES]" name="school_config" size="133656">ptc99.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="Install" size="208984">ptc103.cab</CDSECTION>
    <CDSECTION install="N" location="[CREOCOMMONFILES]" name="apps_data" size="64965894">ptc108.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" location="[CREOCOMMONFILES]" name="ModelCHECK" size="7130452">ptc110.cab</CDSECTION>
    <CDSECTION install="N" language="french" location="[CREOCOMMONFILES]" name="ModelCHECK" size="979595">ptc111.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" language="german" location="[CREOCOMMONFILES]" name="ModelCHECK" size="1522968">ptc112.cab</CDSECTION>
    <CDSECTION install="N" language="italian" location="[CREOCOMMONFILES]" name="ModelCHECK" size="969047">ptc113.cab</CDSECTION>
    <CDSECTION install="N" language="spanish" location="[CREOCOMMONFILES]" name="ModelCHECK" size="934853">ptc114.cab</CDSECTION>
    <CDSECTION install="N" language="japanese" location="[CREOCOMMONFILES]" name="ModelCHECK" size="880315">ptc115.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" language="chinese_cn" location="[CREOCOMMONFILES]" name="ModelCHECK" size="846008">ptc116.cab</CDSECTION>
    <CDSECTION install="N" language="chinese_tw" location="[CREOCOMMONFILES]" name="ModelCHECK" size="847136">ptc117.cab</CDSECTION>
    <CDSECTION install="N" language="korean" location="[CREOCOMMONFILES]" name="ModelCHECK" size="865109">ptc118.cab</CDSECTION>
    <CDSECTION install="N" language="russian" location="[CREOCOMMONFILES]" name="ModelCHECK" size="340200">ptc119.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" location="[CREOCOMMONFILES]" name="ModelCHECK" platform="x86e_win64" size="7084032">ptc120.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" location="[CREOCOMMONFILES]" name="gpost" platform="x86e_win64" size="172338935">ptc121.cab</CDSECTION>
    <CDSECTION install="N" location="[CREOCOMMONFILES]" name="vericut" size="543947925">ptc122.cab</CDSECTION>
    <CDSECTION install="N" location="[CREOCOMMONFILES]" name="vericut" platform="x86e_win64" size="118220965">ptc123.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" location="[CREOCOMMONFILES]" name="jlinkwiz" size="16045347">ptc162.cab</CDSECTION>
    <CDSECTION install="N" location="[CREOCOMMONFILES]" name="otk_cpp_docwiz" size="25472694">ptc163.cab</CDSECTION>
    <CDSECTION install="N" location="[CREOCOMMONFILES]" name="otk_java_docwiz" size="29626146">ptc164.cab</CDSECTION>
    <CDSECTION install="N" location="[CREOCOMMONFILES]" name="pfcvbwiz" size="11676313">ptc165.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" location="[CREOCOMMONFILES]" name="pfcweblinkwiz" size="11970060">ptc166.cab</CDSECTION>
    <CDSECTION install="N" location="[CREOCOMMONFILES]" name="protkwiz" size="68388344">ptc167.cab</CDSECTION>
    <CDSECTION install="N" location="[CREOCOMMONFILES]" name="dbatchc" size="188844">ptc170.cab</CDSECTION>
    <CDSECTION install="N" location="[CREOCOMMONFILES]" name="dbatchchelp" size="592061">ptc171.cab</CDSECTION>
    <CDSECTION install="N" language="russian" location="[CREOCOMMONFILES]" name="dbatchc" size="258050">ptc189.cab</CDSECTION>
    <CDSECTION install="N" language="chinese_cn" location="[CREOCOMMONFILES]" name="dbatchc" size="171110">ptc190.cab</CDSECTION>
    <CDSECTION install="N" language="chinese_cn" location="[CREOCOMMONFILES]" name="dbatchchelp" size="729168">ptc191.cab</CDSECTION>
    <CDSECTION install="N" language="chinese_tw" location="[CREOCOMMONFILES]" name="dbatchc" size="172772">ptc192.cab</CDSECTION>
    <CDSECTION install="N" language="chinese_tw" location="[CREOCOMMONFILES]" name="dbatchchelp" size="853988">ptc193.cab</CDSECTION>
    <CDSECTION install="N" language="french" location="[CREOCOMMONFILES]" name="dbatchc" size="200919">ptc194.cab</CDSECTION>
    <CDSECTION install="N" language="french" location="[CREOCOMMONFILES]" name="dbatchchelp" size="725706">ptc195.cab</CDSECTION>
    <CDSECTION install="N" language="german" location="[CREOCOMMONFILES]" name="dbatchc" size="192233">ptc196.cab</CDSECTION>
    <CDSECTION install="N" language="german" location="[CREOCOMMONFILES]" name="dbatchchelp" size="717347">ptc197.cab</CDSECTION>
    <CDSECTION install="N" language="italian" location="[CREOCOMMONFILES]" name="dbatchc" size="192900">ptc198.cab</CDSECTION>
    <CDSECTION install="N" language="italian" location="[CREOCOMMONFILES]" name="dbatchchelp" size="708678">ptc199.cab</CDSECTION>
    <CDSECTION install="N" language="japanese" location="[CREOCOMMONFILES]" name="dbatchc" size="222791">ptc200.cab</CDSECTION>
    <CDSECTION install="N" language="japanese" location="[CREOCOMMONFILES]" name="dbatchchelp" size="772722">ptc201.cab</CDSECTION>
    <CDSECTION install="N" language="korean" location="[CREOCOMMONFILES]" name="dbatchc" size="203624">ptc202.cab</CDSECTION>
    <CDSECTION install="N" language="korean" location="[CREOCOMMONFILES]" name="dbatchchelp" size="906629">ptc203.cab</CDSECTION>
    <CDSECTION install="N" language="spanish" location="[CREOCOMMONFILES]" name="dbatchc" size="201361">ptc204.cab</CDSECTION>
    <CDSECTION install="N" language="spanish" location="[CREOCOMMONFILES]" name="dbatchchelp" size="723035">ptc205.cab</CDSECTION>
    <CDSECTION install="N" location="[CREOCOMMONFILES]" name="dbatchc" platform="x86e_win64" size="144911872">ptc208.cab</CDSECTION>
    <CDSECTION install="N" location="[CREOCOMMONFILES]" name="fileopensaveas" size="4738307">ptc214.cab</CDSECTION>
    <CDSECTION install="N" language="french" location="[CREOCOMMONFILES]" name="fileopensaveas" size="618305">ptc215.cab</CDSECTION>
    <CDSECTION install="N" language="german" location="[CREOCOMMONFILES]" name="fileopensaveas" size="615629">ptc216.cab</CDSECTION>
    <CDSECTION install="N" language="italian" location="[CREOCOMMONFILES]" name="fileopensaveas" size="616229">ptc217.cab</CDSECTION>
    <CDSECTION install="N" language="spanish" location="[CREOCOMMONFILES]" name="fileopensaveas" size="624912">ptc218.cab</CDSECTION>
    <CDSECTION install="N" language="japanese" location="[CREOCOMMONFILES]" name="fileopensaveas" size="623570">ptc219.cab</CDSECTION>
    <CDSECTION install="N" language="chinese_cn" location="[CREOCOMMONFILES]" name="fileopensaveas" size="569242">ptc220.cab</CDSECTION>
    <CDSECTION install="N" language="chinese_tw" location="[CREOCOMMONFILES]" name="fileopensaveas" size="558589">ptc221.cab</CDSECTION>
    <CDSECTION install="N" language="korean" location="[CREOCOMMONFILES]" name="fileopensaveas" size="595641">ptc222.cab</CDSECTION>
    <CDSECTION install="N" language="russian" location="[CREOCOMMONFILES]" name="fileopensaveas" size="637210">ptc223.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" location="[CREOCOMMONFILES]" name="cma_files" platform="x86e_win64" size="449406681">ptc234.cab</CDSECTION>
    <CDSECTION install="N" location="[CREOCOMMONFILES]" name="jre" platform="x86e_win64" size="124215212">ptc235.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" location="[CREOCOMMONFILES]" name="intf_jt" platform="x86e_win64" size="66408326">ptc236.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" location="[CREOCOMMONFILES]" name="EFX Tree" size="327258011">ptc237.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" location="[CREOCOMMONFILES]" name="efx" platform="x86e_win64" size="47634123">ptc238.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" language="german" location="[CREOCOMMONFILES]" name="efx" size="193279">ptc239.cab</CDSECTION>
    <CDSECTION install="N" language="french" location="[CREOCOMMONFILES]" name="efx" size="278999">ptc240.cab</CDSECTION>
    <CDSECTION install="N" language="italian" location="[CREOCOMMONFILES]" name="efx" size="277527">ptc241.cab</CDSECTION>
    <CDSECTION install="N" language="spanish" location="[CREOCOMMONFILES]" name="efx" size="277330">ptc242.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" language="chinese_cn" location="[CREOCOMMONFILES]" name="efx" size="250245">ptc243.cab</CDSECTION>
    <CDSECTION install="N" language="chinese_tw" location="[CREOCOMMONFILES]" name="efx" size="250738">ptc244.cab</CDSECTION>
    <CDSECTION install="N" language="korean" location="[CREOCOMMONFILES]" name="efx" size="262724">ptc245.cab</CDSECTION>
    <CDSECTION install="N" language="japanese" location="[CREOCOMMONFILES]" name="efx" size="268533">ptc246.cab</CDSECTION>
    <CDSECTION install="N" location="[CREOCOMMONFILES]" name="protoolkit" size="15551723">ptc247.cab</CDSECTION>
    <CDSECTION install="N" location="[CREOCOMMONFILES]" name="protoolkit_non_levela" size="9748890">ptc248.cab</CDSECTION>
    <CDSECTION install="N" language="japanese" location="[CREOCOMMONFILES]" name="protoolkit" size="1149707">ptc250.cab</CDSECTION>
    <CDSECTION install="N" language="chinese_cn" location="[CREOCOMMONFILES]" name="protoolkit" size="512109">ptc251.cab</CDSECTION>
    <CDSECTION install="N" language="chinese_tw" location="[CREOCOMMONFILES]" name="protoolkit" size="634897">ptc252.cab</CDSECTION>
    <CDSECTION install="N" language="french" location="[CREOCOMMONFILES]" name="protoolkit" size="431854">ptc253.cab</CDSECTION>
    <CDSECTION install="N" language="german" location="[CREOCOMMONFILES]" name="protoolkit" size="424748">ptc254.cab</CDSECTION>
    <CDSECTION install="N" language="italian" location="[CREOCOMMONFILES]" name="protoolkit" size="412071">ptc255.cab</CDSECTION>
    <CDSECTION install="N" language="korean" location="[CREOCOMMONFILES]" name="protoolkit" size="623059">ptc256.cab</CDSECTION>
    <CDSECTION install="N" language="spanish" location="[CREOCOMMONFILES]" name="protoolkit" size="422314">ptc257.cab</CDSECTION>
    <CDSECTION install="N" language="russian" location="[CREOCOMMONFILES]" name="protoolkit" size="476569">ptc258.cab</CDSECTION>
    <CDSECTION install="N" language="japanese" location="[CREOCOMMONFILES]" name="protoolkit_non_levela" size="10779174">ptc259.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" location="[CREOCOMMONFILES]" name="java" size="9769624">ptc260.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" location="[CREOCOMMONFILES]" name="weblink" size="1752611">ptc261.cab</CDSECTION>
    <CDSECTION install="N" location="[CREOCOMMONFILES]" name="pfcvb" size="5708801">ptc262.cab</CDSECTION>
    <CDSECTION install="N" location="[CREOCOMMONFILES]" name="protoolkit" platform="x86e_win64" size="724727289">ptc263.cab</CDSECTION>
    <CDSECTION install="N" location="[CREOCOMMONFILES]" name="pfcvb" platform="x86e_win64" size="30389760">ptc264.cab</CDSECTION>
    <CDSECTION install="N" location="[CREOCOMMONFILES]" name="cadds5" size="419573">ptc267.cab</CDSECTION>
    <CDSECTION install="N" location="[CREOCOMMONFILES]" name="cadds5" platform="x86e_win64" size="116192108">ptc269.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" location="[CREOCOMMONFILES]" name="cocreateheadless" platform="x86e_win64" size="288122181">ptc271.cab</CDSECTION>
    <CDSECTION install="N" location="[CREOCOMMONFILES]" name="otk_cpp" size="2585196">ptc272.cab</CDSECTION>
    <CDSECTION install="N" location="[CREOCOMMONFILES]" name="otk_cpp" platform="x86e_win64" size="980488727">ptc273.cab</CDSECTION>
    <CDSECTION install="N" location="[CREOCOMMONFILES]" name="otk_cpp_doc" size="3206539">ptc274.cab</CDSECTION>
    <CDSECTION install="N" location="[CREOCOMMONFILES]" name="otk_java" size="4386989">ptc275.cab</CDSECTION>
    <CDSECTION install="N" location="[CREOCOMMONFILES]" name="otk_java_doc" size="2857564">ptc276.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" name="swim" platform="x86e_win64" size="3898070">ptc277.cab</CDSECTION>
    <CDSECTION install="N" location="[CREOCOMMONFILES]" name="creo_ui_editor" size="4121110">ptc278.cab</CDSECTION>
    <CDSECTION install="N" location="[CREOCOMMONFILES]" name="creo_ui_editor" platform="x86e_win64" size="7777814">ptc280.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" location="[CREOCOMMONFILES]" name="creocalc_files" size="23599">ptc293.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" location="[CREOCOMMONFILES]" name="creocalc_files" platform="x86e_win64" size="31576576">ptc295.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" language="chinese_cn" location="[CREOCOMMONFILES]" name="creocalc_files" size="24894">ptc296.cab</CDSECTION>
    <CDSECTION install="N" language="chinese_tw" location="[CREOCOMMONFILES]" name="creocalc_files" size="24888">ptc297.cab</CDSECTION>
    <CDSECTION install="N" language="russian" location="[CREOCOMMONFILES]" name="creocalc_files" size="26154">ptc298.cab</CDSECTION>
    <CDSECTION install="N" language="korean" location="[CREOCOMMONFILES]" name="creocalc_files" size="25391">ptc299.cab</CDSECTION>
    <CDSECTION install="N" language="japanese" location="[CREOCOMMONFILES]" name="creocalc_files" size="25750">ptc300.cab</CDSECTION>
    <CDSECTION install="N" language="french" location="[CREOCOMMONFILES]" name="creocalc_files" size="25389">ptc301.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" language="german" location="[CREOCOMMONFILES]" name="creocalc_files" size="25375">ptc302.cab</CDSECTION>
    <CDSECTION install="N" language="italian" location="[CREOCOMMONFILES]" name="creocalc_files" size="25376">ptc303.cab</CDSECTION>
    <CDSECTION install="N" language="spanish" location="[CREOCOMMONFILES]" name="creocalc_files" size="25383">ptc304.cab</CDSECTION>
  </DISTRIBUTION>
  <CUSTOM_ACTION dest="[CREOCOMMONFILES]/[THIS_ARCH]/obj/pfclscom.exe" dll="" name="VisualBasicInstallAction" package="vbapi" when="PostInstall"/>
  <CUSTOM_ACTION dest="[CREOCOMMONFILES]/[THIS_ARCH]/obj/proobj.exe" dll="" name="ConfigureOLE" when="PostInstall"/>
  <CUSTOM_ACTION dest="[CREOCOMMONFILES]/[THIS_ARCH]/cma/Bin/IntelMPI/smpd-intel-4.0.3.009-x86.exe" dll="" name="install_MPI_x86" package="creocma" when="PostInstall"/>
  <CUSTOM_ACTION dest="[CREOCOMMONFILES]/[THIS_ARCH]/cma/Bin/IntelMPI/smpd-intel-4.0.3.009-x64.exe" dll="" name="install_MPI_x64" package="creocma" when="PostInstall"/>
  <CUSTOM_ACTION dll="" when="PreUninstall" name="CleanupPHM" dest="[LP]/bin/parametric.exe" args="-cleanup_phm" />
  <!-- QUALITY AGENT is stored with Product Info under HKEY_LOCAL_MACHINE\SOFTWARE\PTC as key -->
  <QUALITY_AGENT enable="N" keyname="QualityAgentOptIn" required="N"/>
  <SHORTCUT allusers="Y" id="pma_shortcut">
    <NAME>PTC Creo Parametric [VERSION] [SHIPCODE]</NAME>
    <ICON>[LP]/install/nt/parametric.ico</ICON>
    <INDEX>0</INDEX>
    <PATH>[LP]/bin/parametric.exe</PATH>
    <WIN7APPID>PTC.Creo_Parametric</WIN7APPID>
    <STARTINDIR>[DOCUMENTS_ALLUSERS]</STARTINDIR>
    <PROGRAMSMENU create="Y" installed="Y">PTC Creo</PROGRAMSMENU>
    <DESKTOP create="Y" installed="Y"/>
  </SHORTCUT>
  <SHORTCUT allusers="Y" id="dbatchc_shortcut" package="dbatchc">
    <NAME>PTC Creo Distributed Batch [VERSION] [SHIPCODE]</NAME>
    <ICON>[LP]/install/nt/dbatchc.ico</ICON>
    <INDEX>0</INDEX>
    <PATH>[LP]/bin/ptcdbatch.bat</PATH>
    <WIN7APPID>PTC.DistributedBATCH</WIN7APPID>
    <PROGRAMSMENU create="Y">PTC Creo</PROGRAMSMENU>
    <DESKTOP create="Y"/>
  </SHORTCUT>
  <SHORTCUT allusers="Y" id="modchk_shortcut" package="modelcheck">
    <NAME>PTC Creo Modelcheck [VERSION] [SHIPCODE]</NAME>
    <ICON>[LP]/install/nt/modelcheck.ico</ICON>
    <INDEX>0</INDEX>
    <PATH>[LP]/bin/modelcheck.bat</PATH>
    <WIN7APPID>PTC.ModelCHECK</WIN7APPID>
  </SHORTCUT>
  <SHORTCUT allusers="Y" id="ui_editor_shortcut" package="uieditor">
    <NAME>PTC Creo UI Editor [VERSION] [SHIPCODE]</NAME>
    <ICON>[LP]/install/nt/creo_logo_ui_editor.ico</ICON>
    <INDEX>0</INDEX>
    <PATH>[CREOCOMMONFILES]/creo_ui_editor/bin/creo_ui_editor.bat</PATH>
    <WIN7APPID>PTC.UiEditor</WIN7APPID>
  </SHORTCUT>
  <PSF_TEMPLATE dest="[LP]/bin/parametric.psf" id="parametric" name="CreoPma" source="psf_templates.xml">
    <EXE>parametric.exe</EXE>
    <LICTYPE name="CreoPma">PTC Creo Parametric</LICTYPE>
    <PREFIX>CREOPMA PROE</PREFIX>
    <DESCRIPTION>PTC Creo Parametric (default)</DESCRIPTION>
    <LICENSE_IDENTIFIERS/>
    <FEATURE_NAME/>
    <FILTER_DROP>211 212 157 161</FILTER_DROP>
    <DFOR_PATH>%PRO_DIRECTORY%\libs\dfor\lib</DFOR_PATH>
    <CV_ENV_HOME>%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\CV140</CV_ENV_HOME>
  </PSF_TEMPLATE>
  <PSF dest="[LP]/bin/parametric.psf" id="parametric" installed="Y" name="parametric" source="psf_templates.xml">
    <LICENSE_IDENTIFIERS>7788@desogpr120</LICENSE_IDENTIFIERS>
    <FEATURE_NAME>PROE_EngineerIIAAX PROE_FAPAAX PROE_EngineerIII</FEATURE_NAME>
  </PSF>
  <PSF dest="[LP]/bin/cocreatesim.psf" id="cocreatesim" installed="Y" name="cocreatesim" package="coch" source="psf_templates.xml">
    <EXE>cocreatesim.exe</EXE>
    <MECHEXE>parametric.exe</MECHEXE>
    <LICTYPE name="CoCreateSim">CoCreateSim</LICTYPE>
    <PREFIX>CREOSIM</PREFIX>
    <DESCRIPTION>PTC Creo CoCreateSim (default)</DESCRIPTION>
  </PSF>
  <REGISTRY>
    <VALUE default="psfFile" id=".psf" installed="Y" key="[HKCR]"/>
    <VALUE default="phaFile" id=".pha" installed="Y" key="[HKCR]"/>
    <VALUE default="asmFile" id=".asm" installed="Y" key="[HKCR]"/>
    <VALUE default="dgmFile" id=".dgm" installed="Y" key="[HKCR]"/>
    <VALUE default="drwFile" id=".drw" installed="Y" key="[HKCR]"/>
    <VALUE default="frmFile" id=".frm" installed="Y" key="[HKCR]"/>
    <VALUE default="layFile" id=".lay" installed="Y" key="[HKCR]"/>
    <VALUE default="mfgFile" id=".mfg" installed="Y" key="[HKCR]"/>
    <VALUE default="mrkFile" id=".mrk" installed="Y" key="[HKCR]"/>
    <VALUE default="prtFile" id=".prt" installed="Y" key="[HKCR]"/>
    <VALUE default="secFile" id=".sec" installed="Y" key="[HKCR]"/>
    <VALUE default="Creo Versioned File" id="creoFile" installed="Y" key="[HKCR]"/>
    <VALUE default="PTC.Creo_Parametric" id="creoFile" installed="Y" key="[HKCR]" valuename="AppUserModelID"/>
    <VALUE default="[ICON],0" id="DefaultIcon" installed="Y" key="[HKCR]creoFile"/>
    <VALUE default="" id="Shell" installed="Y" key="[HKCR]creoFile"/>
    <VALUE default="[OpenWith]" id="Open" installed="Y" key="[HKCR]creoFile/Shell"/>
    <VALUE default="&quot;[LP]/bin/parametric.exe&quot; &quot;%1&quot;" id="Command" installed="Y" key="[HKCR]creoFile/Shell/Open"/>
    <VALUE default="PTC Startup File" id="psfFile" installed="Y" key="[HKCR]"/>
    <VALUE default="[ICON],0" id="DefaultIcon" installed="Y" key="[HKCR]psfFile"/>
    <VALUE default="" id="Shell" installed="Y" key="[HKCR]psfFile"/>
    <VALUE default="[OpenWith]" id="Open" installed="Y" key="[HKCR]psfFile/Shell"/>
    <VALUE default="&quot;[LP]/bin/parametric.exe&quot; &quot;%1&quot;" id="Command" installed="Y" key="[HKCR]psfFile/Shell/Open"/>
    <VALUE default="PTC Helper App File" id="phaFile" installed="Y" key="[HKCR]"/>
    <VALUE default="[ICON],0" id="DefaultIcon" installed="Y" key="[HKCR]phaFile"/>
    <VALUE default="" id="Shell" installed="Y" key="[HKCR]phaFile"/>
    <VALUE default="[OpenWith]" id="Open" installed="Y" key="[HKCR]phaFile/Shell"/>
    <VALUE default="&quot;[LP]/bin/parametric.exe&quot; &quot;%1&quot;" id="Command" installed="Y" key="[HKCR]phaFile/Shell/Open"/>
    <VALUE default="Creo Assembly File" id="asmFile" installed="Y" key="[HKCR]"/>
    <VALUE default="PTC.Creo_Parametric" id="asmFile" installed="Y" key="[HKCR]" valuename="AppUserModelID"/>
    <VALUE default="[ICON],0" id="DefaultIcon" installed="Y" key="[HKCR]asmFile"/>
    <VALUE default="" id="Shell" installed="Y" key="[HKCR]asmFile"/>
    <VALUE default="[OpenWith]" id="Open" installed="Y" key="[HKCR]asmFile/Shell"/>
    <VALUE default="&quot;[LP]/bin/parametric.exe&quot; &quot;%1&quot;" id="Command" installed="Y" key="[HKCR]asmFile/Shell/Open"/>
    <VALUE default="Creo Diagram File" id="dgmFile" installed="Y" key="[HKCR]"/>
    <VALUE default="PTC.Creo_Parametric" id="dgmFile" installed="Y" key="[HKCR]" valuename="AppUserModelID"/>
    <VALUE default="[ICON],0" id="DefaultIcon" installed="Y" key="[HKCR]dgmFile"/>
    <VALUE default="" id="Shell" installed="Y" key="[HKCR]dgmFile"/>
    <VALUE default="[OpenWith]" id="Open" installed="Y" key="[HKCR]dgmFile/Shell"/>
    <VALUE default="&quot;[LP]/bin/parametric.exe&quot; &quot;%1&quot;" id="Command" installed="Y" key="[HKCR]dgmFile/Shell/Open"/>
    <VALUE default="Creo Drawing File" id="drwFile" installed="Y" key="[HKCR]"/>
    <VALUE default="PTC.Creo_Parametric" id="drwFile" installed="Y" key="[HKCR]" valuename="AppUserModelID"/>
    <VALUE default="[ICON],0" id="DefaultIcon" installed="Y" key="[HKCR]drwFile"/>
    <VALUE default="" id="Shell" installed="Y" key="[HKCR]drwFile"/>
    <VALUE default="[OpenWith]" id="Open" installed="Y" key="[HKCR]drwFile/Shell"/>
    <VALUE default="&quot;[LP]/bin/parametric.exe&quot; &quot;%1&quot;" id="Command" installed="Y" key="[HKCR]drwFile/Shell/Open"/>
    <VALUE default="Creo Format File" id="frmFile" installed="Y" key="[HKCR]"/>
    <VALUE default="PTC.Creo_Parametric" id="frmFile" installed="Y" key="[HKCR]" valuename="AppUserModelID"/>
    <VALUE default="[ICON],0" id="DefaultIcon" installed="Y" key="[HKCR]frmFile"/>
    <VALUE default="" id="Shell" installed="Y" key="[HKCR]frmFile"/>
    <VALUE default="[OpenWith]" id="Open" installed="Y" key="[HKCR]frmFile/Shell"/>
    <VALUE default="&quot;[LP]/bin/parametric.exe&quot; &quot;%1&quot;" id="Command" installed="Y" key="[HKCR]frmFile/Shell/Open"/>
    <VALUE default="Creo Notebook File" id="layFile" installed="Y" key="[HKCR]"/>
    <VALUE default="PTC.Creo_Parametric" id="layFile" installed="Y" key="[HKCR]" valuename="AppUserModelID"/>
    <VALUE default="[ICON],0" id="DefaultIcon" installed="Y" key="[HKCR]layFile"/>
    <VALUE default="" id="Shell" installed="Y" key="[HKCR]layFile"/>
    <VALUE default="[OpenWith]" id="Open" installed="Y" key="[HKCR]layFile/Shell"/>
    <VALUE default="&quot;[LP]/bin/parametric.exe&quot; &quot;%1&quot;" id="Command" installed="Y" key="[HKCR]layFile/Shell/Open"/>
    <VALUE default="Creo Manufacturing File" id="mfgFile" installed="Y" key="[HKCR]"/>
    <VALUE default="PTC.Creo_Parametric" id="mfgFile" installed="Y" key="[HKCR]" valuename="AppUserModelID"/>
    <VALUE default="[ICON],0" id="DefaultIcon" installed="Y" key="[HKCR]mfgFile"/>
    <VALUE default="" id="Shell" installed="Y" key="[HKCR]mfgFile"/>
    <VALUE default="[OpenWith]" id="Open" installed="Y" key="[HKCR]mfgFile/Shell"/>
    <VALUE default="&quot;[LP]/bin/parametric.exe&quot; &quot;%1&quot;" id="Command" installed="Y" key="[HKCR]mfgFile/Shell/Open"/>
    <VALUE default="Creo Markup File" id="mrkFile" installed="Y" key="[HKCR]"/>
    <VALUE default="PTC.Creo_Parametric" id="mrkFile" installed="Y" key="[HKCR]" valuename="AppUserModelID"/>
    <VALUE default="[ICON],0" id="DefaultIcon" installed="Y" key="[HKCR]mrkFile"/>
    <VALUE default="" id="Shell" installed="Y" key="[HKCR]mrkFile"/>
    <VALUE default="[OpenWith]" id="Open" installed="Y" key="[HKCR]mrkFile/Shell"/>
    <VALUE default="&quot;[LP]/bin/parametric.exe&quot; &quot;%1&quot;" id="Command" installed="Y" key="[HKCR]mrkFile/Shell/Open"/>
    <VALUE default="Creo Part File" id="prtFile" installed="Y" key="[HKCR]"/>
    <VALUE default="PTC.Creo_Parametric" id="prtFile" installed="Y" key="[HKCR]" valuename="AppUserModelID"/>
    <VALUE default="[ICON],0" id="DefaultIcon" installed="Y" key="[HKCR]prtFile"/>
    <VALUE default="" id="Shell" installed="Y" key="[HKCR]prtFile"/>
    <VALUE default="[OpenWith]" id="Open" installed="Y" key="[HKCR]prtFile/Shell"/>
    <VALUE default="&quot;[LP]/bin/parametric.exe&quot; &quot;%1&quot;" id="Command" installed="Y" key="[HKCR]prtFile/Shell/Open"/>
    <VALUE default="Creo Section File" id="secFile" installed="Y" key="[HKCR]"/>
    <VALUE default="PTC.Creo_Parametric" id="secFile" installed="Y" key="[HKCR]" valuename="AppUserModelID"/>
    <VALUE default="[ICON],0" id="DefaultIcon" installed="Y" key="[HKCR]secFile"/>
    <VALUE default="" id="Shell" installed="Y" key="[HKCR]secFile"/>
    <VALUE default="[OpenWith]" id="Open" installed="Y" key="[HKCR]secFile/Shell"/>
    <VALUE default="&quot;[LP]/bin/parametric.exe&quot; &quot;%1&quot;" id="Command" installed="Y" key="[HKCR]secFile/Shell/Open"/>
    <!-- check this... used for ppa -->
    <VALUE default="PTC.Creo_Parametric" id="parametric.exe" installed="Y" key="[HKCR]Applications"/>
    <VALUE default="" id="Shell" installed="Y" key="[HKCR]Applications/parametric.exe"/>
    <VALUE default="[OpenWith]" id="Open" installed="Y" key="[HKCR]Applications/parametric.exe/Shell"/>
    <VALUE default="&quot;[LP]/bin/parametric.exe&quot; &quot;%1&quot;" id="Command" installed="Y" key="[HKCR]Applications/parametric.exe/Shell/Open"/>
  </REGISTRY>
</PRODUCT>
smi.p
<!-- 12-Sep-12 P-20-14 TWH      undo #20 update ltr_prefix -->
<PRODUCT datecode="2015080" family="Creo" name="PTC Creo Simulate" parent="creobase.xml" shipcode="M040" tag="sim.xml" version="3.0">
  <PROPERTIES>
    <PROPERTY name="ltr_prefix">CREOSIM MECBASICUI MECSTRUCUI MECTHERMUI CREOPMA PROE</PROPERTY>
    <PROPERTY name="ARPURLInfoAbout">http://www.ptc.com/product/creo/simulate</PROPERTY>
    <PROPERTY name="[LP]">[INSTALLBASE]/Creo3/[SHIPCODE]/Simulate</PROPERTY>
    <PROPERTY name="[OpenWith]">Mit PTC Creo Simulate öffnen</PROPERTY>
    <PROPERTY name="[ICON]">[LP]/install/nt/simulate.ico</PROPERTY>
    <PROPERTY name="SimulateLicenseTypes">MEC_BASIC_UI MEC_BASIC_ENG STRUCT_UI STRUCT_ENGINE STRUCT_THERMAL_UI STRUCT_THERMAL_ENGINE MEC_ELITE_UI MEC_ELITE_ENG</PROPERTY>
    <PROPERTY name="MEC_BASIC_UI" prefix="MECBASICUI">MECBASICUI_License</PROPERTY>
    <PROPERTY name="MEC_BASIC_ENG" prefix="MECBASICENG">MECBASICENG_License</PROPERTY>
    <PROPERTY name="STRUCT_UI" prefix="MECSTRUCUI">&lt;No license features&gt;</PROPERTY>
    <PROPERTY name="STRUCT_ENGINE" prefix="MECSTRUCENG">&lt;No license features&gt;</PROPERTY>
    <PROPERTY name="STRUCT_THERMAL_UI" prefix="MECTHERMUI">&lt;No license features&gt;</PROPERTY>
    <PROPERTY name="STRUCT_THERMAL_ENGINE" prefix="MECTHERMENG">&lt;No license features&gt;</PROPERTY>
    <PROPERTY name="MEC_ELITE_UI" prefix="MECELITEUI">&lt;No license features&gt;</PROPERTY>
    <PROPERTY name="MEC_ELITE_ENG" prefix="MECELITEENG">&lt;No license features&gt;</PROPERTY>
    <PROPERTY name="[OLDLP]">[INSTALLBASE]/Creo3/[OLDSHIPCODE]/Simulate</PROPERTY>
      <PROPERTY msgid="145002788" name="ToolTip">pimToolTipSimulate</PROPERTY>
      <PROPERTY name="invoke_phm_exe">[LP]/bin/simulate.exe</PROPERTY>
  </PROPERTIES>
    <LANGUAGES>
      <!-- <LANGUAGE name="italian" install="N" installed="N" >Italian</LANGUAGE> -->
      <!-- <LANGUAGE name="spanish" install="N" installed="N" >Spanish</LANGUAGE> -->
      <!-- <LANGUAGE name="korean" install="N" installed="N" >Korean</LANGUAGE> -->
      <!-- <LANGUAGE name="chinese_tw" install="N" installed="N" >Chinese traditional</LANGUAGE> -->
    </LANGUAGES>
    <PLATFORMS>
    </PLATFORMS>
    <PACKAGES>
      <PACKAGE hidden="N" install="Y" label="PTC Creo Simulate" name="sim_base" parent="" required="Y">
        <FEATURE>mech_applstart</FEATURE>
        <FEATURE location="[CREOCOMMONFILES]">mechInstall</FEATURE>
        <FEATURE location="[CREOCOMMONFILES]">mech</FEATURE>
        <FEATURE location="[CREOCOMMONFILES]">mech2</FEATURE>
        <FEATURE location="[CREOCOMMONFILES]">mech3</FEATURE>
        <FEATURE location="[CREOCOMMONFILES]">mech4</FEATURE>
        <FEATURE location="[CREOCOMMONFILES]">mech5</FEATURE>
        <FEATURE location="[CREOCOMMONFILES]">mech6</FEATURE>
        <FEATURE location="[CREOCOMMONFILES]">mech7</FEATURE>
        <FEATURE location="[CREOCOMMONFILES]">mech8</FEATURE>
        <FEATURE location="[CREOCOMMONFILES]">mech9</FEATURE>
        <FEATURE location="[CREOCOMMONFILES]">mech10</FEATURE>
        <FEATURE location="[CREOCOMMONFILES]">mech11</FEATURE>
        <FEATURE location="[CREOCOMMONFILES]">mech12</FEATURE>
        <FEATURE location="[CREOCOMMONFILES]">mech13</FEATURE>
        <FEATURE location="[CREOCOMMONFILES]">mech14</FEATURE>
        <FEATURE location="[CREOCOMMONFILES]">mech15</FEATURE>
        <SCRIPT dest="[LP]/bin/convert_image.bat" name="convert_image" source="creo_templates.xml"/>
        <SCRIPT dest="[LP]/bin/simulate_borrow.bat" name="simulate_borrow" source="creo_templates.xml"/>
        <SCRIPT dest="[LP]/bin/pro_from_feas.bat" name="pro_from_feas" source="creo_templates.xml"/>
        <SCRIPT dest="[CREOCOMMONFILES]/mech/install/nt/mech_lmlicfile.bat" name="mech_lmlicfile" source="creo_templates.xml"/>
      </PACKAGE>
         <PACKAGE hidden="N" install="Y" label="Verifikationsmodelle" name="vermodels" parent="" required="N">
              <FEATURE location="[CREOCOMMONFILES]">verification_models</FEATURE>
              <FEATURE location="[CREOCOMMONFILES]">Verification Models: Motion</FEATURE>
       </PACKAGE>
      <PACKAGE hidden="N" install="Y" label="PTC Creo Simulate Distributed Computing Extension" name="dbatchc" parent="" required="N">
        <FEATURE location="[CREOCOMMONFILES]">iculibs</FEATURE>
        <FEATURE location="[CREOCOMMONFILES]">Mozilla</FEATURE>
        <SCRIPT dest="[LP]/bin/ptcdbatch.bat" name="ptcdbatch_sim" source="creo_templates.xml"/>
        <SCRIPT dest="[LP]/bin/dcadsetup.bat" name="dcadsetup_sim" source="creo_templates.xml"/>
        <SCRIPT dest="[LP]/bin/dcadshutdown.bat" name="dcadshutdown" source="creo_templates.xml"/>
      </PACKAGE>
      <PACKAGE hidden="N" install="Y" label="Direct Modeling Konvertierer" name="coch" parent="" required="N">
      </PACKAGE>
    </PACKAGES>
    <CDSECTION install="Y" installed="Y" name="mech_applstart" platform="x86e_win64" size="25295872">ptc81.cab</CDSECTION>
    <CDSECTION install="Y" installed="Y" location="[CREOCOMMONFILES]" name="mechInstall" size="910517">ptc146.cab</CDSECTION>
    <CDSECTION install="Y" location="[CREOCOMMONFILES]" name="mech" size="2553650">ptc147.cab</CDSECTION>
    <CDSECTION install="Y" language="chinese_cn" location="[CREOCOMMONFILES]" name="mech" size="1479042">ptc148.cab</CDSECTION>
    <CDSECTION install="N" language="french" location="[CREOCOMMONFILES]" name="mech" size="1864667">ptc149.cab</CDSECTION>
    <CDSECTION install="Y" language="german" location="[CREOCOMMONFILES]" name="mech" size="1798237">ptc150.cab</CDSECTION>
    <CDSECTION install="N" language="japanese" location="[CREOCOMMONFILES]" name="mech" size="1948866">ptc151.cab</CDSECTION>
    <CDSECTION install="N" language="russian" location="[CREOCOMMONFILES]" name="mech" size="2568439">ptc152.cab</CDSECTION>
    <CDSECTION install="Y" location="[CREOCOMMONFILES]" name="verification_models" size="67174666">ptc153.cab</CDSECTION>
    <CDSECTION install="Y" location="[CREOCOMMONFILES]" name="mech2" platform="x86e_win64" size="108757504">ptc154.cab</CDSECTION>
    <CDSECTION install="Y" location="[CREOCOMMONFILES]" name="mech" platform="x86e_win64" size="214203000">ptc155.cab</CDSECTION>
    <CDSECTION install="Y" language="chinese_cn" location="[CREOCOMMONFILES]" name="mech" platform="x86e_win64" size="273749">ptc156.cab</CDSECTION>
    <CDSECTION install="N" language="french" location="[CREOCOMMONFILES]" name="mech" platform="x86e_win64" size="299497">ptc157.cab</CDSECTION>
    <CDSECTION install="Y" language="german" location="[CREOCOMMONFILES]" name="mech" platform="x86e_win64" size="298695">ptc158.cab</CDSECTION>
    <CDSECTION install="N" language="japanese" location="[CREOCOMMONFILES]" name="mech" platform="x86e_win64" size="883222">ptc159.cab</CDSECTION>
    <CDSECTION install="N" language="russian" location="[CREOCOMMONFILES]" name="mech" platform="x86e_win64" size="273305">ptc160.cab</CDSECTION>
    <CDSECTION install="Y" location="[CREOCOMMONFILES]" name="dbatchc" size="188844">ptc170.cab</CDSECTION>
    <CDSECTION install="Y" location="[CREOCOMMONFILES]" name="dbatchchelp" size="592061">ptc171.cab</CDSECTION>
    <CDSECTION install="Y" language="chinese_cn" location="[CREOCOMMONFILES]" name="dbatchc" size="171110">ptc190.cab</CDSECTION>
    <CDSECTION install="Y" language="chinese_cn" location="[CREOCOMMONFILES]" name="dbatchchelp" size="729168">ptc191.cab</CDSECTION>
    <CDSECTION install="Y" language="german" location="[CREOCOMMONFILES]" name="dbatchc" size="192233">ptc196.cab</CDSECTION>
    <CDSECTION install="Y" language="german" location="[CREOCOMMONFILES]" name="dbatchchelp" size="717347">ptc197.cab</CDSECTION>
    <CDSECTION install="Y" location="[CREOCOMMONFILES]" name="dbatchc" platform="x86e_win64" size="144911872">ptc208.cab</CDSECTION>
    <CDSECTION install="Y" location="[CREOCOMMONFILES]" name="fileopensaveas" size="4738307">ptc214.cab</CDSECTION>
    <CDSECTION install="Y" language="german" location="[CREOCOMMONFILES]" name="fileopensaveas" size="615629">ptc216.cab</CDSECTION>
    <CDSECTION install="Y" language="chinese_cn" location="[CREOCOMMONFILES]" name="fileopensaveas" size="569242">ptc220.cab</CDSECTION>
    <CDSECTION install="Y" location="[CREOCOMMONFILES]" name="iculibs" platform="x86e_win64" size="45064192">ptc270.cab</CDSECTION>
    <CDSECTION install="Y" location="[CREOCOMMONFILES]" name="cocreateheadless" platform="x86e_win64" size="288122181">ptc271.cab</CDSECTION>
  </DISTRIBUTION>
  <CUSTOM_ACTION dest="[CREOCOMMONFILES]/mech/text/licensing/mech/feature.dat" dll="" name="CreateSimLegacyFeatureDotDat" when="PostCopy"/>
  <CUSTOM_ACTION dest="[CREOCOMMONFILES]/mech/text/licensing/mech/feature.dat" dll="" name="CreateSimLegacyFeatureDotDat" when="Reconfigure"/>
  <SHORTCUT allusers="Y" id="sim_shortcut">
    <NAME>PTC Creo Simulate [VERSION] [SHIPCODE]</NAME>
    <ICON>[LP]/install/nt/simulate.ico</ICON>
    <INDEX>0</INDEX>
    <PATH>[LP]/bin/simulate.exe</PATH>
    <WIN7APPID>PTC.Creo_Simulate</WIN7APPID>
  </SHORTCUT>
    <INDEX>0</INDEX>
  </SHORTCUT>
  <PSF_TEMPLATE dest="[LP]/bin/simulate.psf" id="simulate" name="simulate" source="psf_templates.xml">
    <EXE>simulate.exe</EXE>
    <BAT>simulate1.bat</BAT>
    <LICTYPE name="simulate">PTC Creo Simulate</LICTYPE>
    <PREFIX>CREOSIM CREOPMA PROE</PREFIX>
    <DESCRIPTION>PTC Creo Simulate (default)</DESCRIPTION>
    <FEATURE_NAME/>
    <FILTER_KEEP>9 155 163 251 219 341</FILTER_KEEP>
  </PSF_TEMPLATE>
  <PSF dest="[LP]/bin/simulate.psf" id="simulate" name="simulate" source="psf_templates.xml">
  </PSF>
  <PSF create="N" dest="[LP]/bin/cocreatesim.psf" id="cocreatesim" name="cocreatesim" package="coch" source="psf_templates.xml">
    <MECHEXE>simulate.exe</MECHEXE>
  </PSF>
  <REGISTRY>
    <VALUE default="psfFile" id=".psf" key="[HKCR]"/>
    <VALUE default="asmFile" id=".asm" key="[HKCR]"/>
    <VALUE default="prtFile" id=".prt" key="[HKCR]"/>
    <VALUE default="Creo Versioned File" id="creoFile" key="[HKCR]"/>
    <VALUE default="PTC.Creo_Simulate" id="creoFile" key="[HKCR]" valuename="AppUserModelID"/>
    <VALUE default="[ICON],0" id="DefaultIcon" key="[HKCR]creoFile"/>
    <VALUE default="" id="Shell" key="[HKCR]creoFile"/>
    <VALUE default="[OpenWith]" id="Open" key="[HKCR]creoFile/Shell"/>
    <VALUE default="&quot;[LP]/bin/simulate.exe&quot; &quot;%1&quot;" id="Command" key="[HKCR]creoFile/Shell/Open"/>
    <VALUE default="PTC Startup File" id="psfFile" key="[HKCR]"/>
    <VALUE default="[ICON],0" id="DefaultIcon" key="[HKCR]psfFile"/>
    <VALUE default="[OpenWith]" id="Open" key="[HKCR]psfFile/Shell"/>
    <VALUE default="&quot;[LP]/bin/simulate.exe&quot; &quot;%1&quot;" id="Command" key="[HKCR]psfFile/Shell/Open"/>
    <VALUE default="Creo Assembly File" id="asmFile" key="[HKCR]"/>
    <VALUE default="PTC.Creo_Simulate" id="asmFile" key="[HKCR]" valuename="AppUserModelID"/>
    <VALUE default="[ICON],0" id="DefaultIcon" key="[HKCR]asmFile"/>
    <VALUE default="[OpenWith]" id="Open" key="[HKCR]asmFile/Shell"/>
    <VALUE default="&quot;[LP]/bin/simulate.exe&quot; &quot;%1&quot;" id="Command" key="[HKCR]asmFile/Shell/Open"/>
    <VALUE default="Creo Part File" id="prtFile" key="[HKCR]"/>
    <VALUE default="PTC.Creo_Simulate" id="prtFile" key="[HKCR]" valuename="AppUserModelID"/>
    <VALUE default="[ICON],0" id="DefaultIcon" key="[HKCR]prtFile"/>
    <VALUE default="[OpenWith]" id="Open" key="[HKCR]prtFile/Shell"/>
    <VALUE default="&quot;[LP]/bin/simulate.exe&quot; &quot;%1&quot;" id="Command" key="[HKCR]prtFile/Shell/Open"/>
    <VALUE default="PTC.Creo_Simulate" id="simulate.exe" key="[HKCR]Applications"/>
    <VALUE default="" id="Shell" key="[HKCR]Applications/simulate.exe"/>
    <VALUE default="[OpenWith]" id="Open" key="[HKCR]Applications/simulate.exe/Shell"/>
    <VALUE default="&quot;[LP]/bin/simulate.exe&quot; &quot;%1&quot;" id="Command" key="[HKCR]Applications/simulate.exe/Shell/Open"/>
  </REGISTRY>
</PRODUCT>
Hermann,
I think it would be better to attach XML files using a procedure described in How to attach file when you Reply to a discussion.
Martin Hanak
Martin Hanák
STEVEG
(To:Dmi3U)
Dmitry,
All I did was change two lines in the qualityagent.xml file.
<PROPERTY name="installdir">[PROGRAMFILES]/PTC</PROPERTY>           to
<PROPERTY name="installdir">C:\apps\Creo2</PROPERTY>
<PROPERTY name="[INSTALLBASE]">[PROGRAMFILES]/PTC</PROPERTY>       to
<PROPERTY name="[INSTALLBASE]">C:\apps\Creo2</PROPERTY>
Dmi3U
(To:Dmi3U)
Thanks to Steve and Hermann,
Unfortunately, my problem is still not resolved:  PTC Creo Platform Agent (as well as thumbviewer and creo view express) is still installing to c:\Program Files (x86)\Common Files
Just to clarify: it is only "add on" software that is going to c:\Program Files (x86)\Common Files instead of c:\PTC
Thank you,
Dmitry
dgschaefer
21-Topaz II
(To:Dmi3U)
I'm going through making my silent install script for Creo 3 and came across this in the install guide which may help you:
If you have not specified the APPLICATIONFOLDER property, the default
installation path is used. To override this path, specify the
APPLICATIONFOLDER property at the command prompt as shown in the
following example:
“start /w <dvd>:\install\addon\pvx32_64\CreoSetup.exe
/vADDLOCAL=”ALL” APPLICATIONFOLDER=”c:\ptc\CreoViewExpress” /qn”
This is under the section for Creo View Express, not sure how or if it would apply to the others.
Good luck!
LinkedIn
