what this error in creation of dll file
kguru
x64\Debug\pt_utils.obj x64\Debug\main.obj D:/protoolkit/x86e_win64/obj/protk_dll.lib libcmt.lib kernel32.lib user32.lib wsock32.lib advapi32.lib mpr.lib winspool.lib netapi32.lib psapi.lib gdi32.lib shell32.lib comdlg32.lib ole32.lib ws2_32.lib
1>     Creating library x64\Debug\main.lib and object x64\Debug\main.exp
1>protk_dll.lib(pdp_pdevtk.obj) : error LNK2019: unresolved external symbol user_initialize referenced in function user_initialize_plus
1>protk_dll.lib(pdp_pdevtk.obj) : error LNK2019: unresolved external symbol user_terminate referenced in function user_terminate_plus
1>x64\Debug\main.dll : fatal error LNK1120: 2 unresolved externals
1>NMAKE : fatal error U1077: '"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\bin\x86_amd64\link.EXE"' : return code '0x460'
1>  Stop.
1>NMAKE : fatal error U1077: '"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\bin\nmake.EXE"' : return code '0x2'
1>  Stop.
1>C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\Microsoft.MakeFile.Targets(43,5): error MSB3073: The command "nmake /f MAKEFILE rebuild_dll" exited with code 2.
========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========
PARTHIBAN_K
(To:kguru)
→ There is some reference missing with your code.
→ Check your have properly mentioned Include directories and the Library directories  in configuration properties of VC++ Directories
→ Check your Additional Include Directories in the C/C++ General properties
→ Also Check the project configuration is x64  for x64 version of Creo
Parthiban Kannan
href="https://www.linkedin.com/in/parthiban-kannan/" target="_blank"
wtuttle
(To:kguru)
Have you been able to resolve the error? I'm receiving the same error trying to create a DLL (using a makefile). I do not receive an error when creating an EXE.
PARTHIBAN_K
(To:wtuttle)
Hello WILLIAM TUTTLE‌ If your application works fine with  .exe and not working in dll means you may missed some additional dependencies in you Linker configuration
Check the following static library added with your Additional dependencies
kernel32.lib
user32.lib
gdi32.lib
winspool.lib
comdlg32.lib
advapi32.lib
shell32.lib
ole32.lib
oleaut32.lib
uuid.lib
odbc32.lib
odbccp32.lib
These libraries are windows library file which defaults come with win32 application and we have to add in Make File or Dynamic Library Project
Parthiban Kannan
PARTHIBAN_K
(To:kguru)
WILLIAM TUTTLE‌, keerthana guru‌ can you post your Makefile here
Parthiban Kannan
Parthiban ,
These library files (winspool.lib advapi32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib)  were not in the original make file. I have added them and re-ran the make file – I still receive the error.
Bill
# Libraries
PTCLIBS = $(PROTOOL_SYS)/obj/protoolkit_NU.lib    \
$(ICU_PATH)/ucore.lib                   \
$(ICU_PATH)/udata.lib
PTCLIBS_DLL = $(PROTOOL_SYS)/obj/protk_dll_NU.lib \
LIBS = libcmt.lib kernel32.lib user32.lib wsock32.lib advapi32.lib mpr.lib winspool.lib netapi32.lib psapi.lib gdi32.lib shell32.lib comdlg32.lib ole32.lib ws2_32.lib winspool.lib advapi32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib
Error
   Creating library checks.lib and object checks.exp
protk_dll_NU.lib(pdp_pdevtk.obj) : error LNK2019: unresolved external symbol user_initialize referenced in function user_initialize_plus
protk_dll_NU.lib(pdp_pdevtk.obj) : error LNK2019: unresolved external symbol user_terminate referenced in function user_terminate_plus
  1. checks.dll : fatal error LNK1120: 2 unresolved externals
NMAKE : fatal error U1077: '"C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\BIN\x86_amd64\link.EXE"' : return code '0x460'
  1. Stop.
Press any key to continue . . .
PARTHIBAN_K
(To:wtuttle)
Hi WILLIAM TUTTLE‌,
make sure your project configuration is Makefile and Platform(x64).
Parthiban Kannan
