#include "ProToolkit.h"
#include "user_tk_error.h"
#include "ProMdl.h"
#include "ProMenu.h"
#include "ProMessage.h"
#include "ProNotify.h"
#include "ProObjects.h"
#include "ProUtil.h"
#include "ProTKRunTime.h"
static wchar_t msgfil[30];
//ProName msgfil;
//wchar_t msgfil[]=L"usermsg.txt";
//wchar_t *msgfil=new wchar_t;
//static ProFileName msgfil;
//static wchar_t msgfil[]={'u','s','e','r','m','s','g','.','t','x','t','\0'};
int UserPartStatus()
ProMdl p_part;
ProMdldata info;
ProBoolean is_modified;
ProError err;
err=ProMdlCurrentGet(&p_part);
ERROR_CHECK("UserPartStatus","ProMdlCurrentGet",err);
err=ProMdlDataGet(p_part,&info);
ERROR_CHECK("UserPartStatus","ProMdlDataGet",err);
ProMdlModificationVerify(p_part,&is_modified);
ERROR_CHECK("UserPartStatus","ProMdlModificationVerify",err);
if (is_modified==PRO_B_TRUE)
ProMessageDisplay(msgfil,"USER Current object: %0w.%1w (MODIFIED)",info.name,info.type);
else
ProMessageDisplay(msgfil,"USER Current object: %0w.%1w",info.name,info.type);
return 0;
ProError UserCheckPart()
return(PRO_TK_NO_ERROR);
extern "C" int user_initialize()
int menu_id;
ProStringToWstring(msgfil,"usermsg.txt");
ProMenuFileRegister("part","part.mnu",&menu_id);
ProMenuAuxfileRegister("part","part.aux",&menu_id);
ProMenubuttonActionSet("part","Status",(ProMenubuttonAction)UserPartStatus,NULL,0);
ProNotificationSet(PRO_MDL_SAVE_PRE,UserCheckPart);
return (0);
extern "C" void user_terminate()
ProTKPrintf ("Pro/TOOLKIT application terminated successfully\n");
dll file was created.
Warning 1 warning MSB8005: The property 'NMakeCleanCommandLine' doesn't exist. Skipping... C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\Microsoft.MakeFile.Targets 32 6 testing
2 IntelliSense: too many arguments in function call d:\toolkit\testing\testing\testing.cpp 35 21 testing
3 IntelliSense: too many arguments in function call d:\toolkit\testing\testing\testing.cpp 37 21 testing
Hi Keerthana,
Please add "#define PRO_USE_VAR_ARGS" to your code (I personally typically place it in a header file).
That should fix your problem.
James Sullivan
sorry.
I can't understand
Change your code to this:
#define PRO_USE_VAR_ARGS // <------- ADD THIS TO ENABLE ARGUMENTS FOR ProMessageDisplay
#include "user_tk_error.h"#include "ProMdl.h"
//ProName msgfil;
//static wchar_t msgfil[]={'u','s','e','r','m','s','g','.','t','x','t','\0'};int UserPartStatus()
ProMdl p_part;
ProMdldata info;
ProError err;err=ProMdlCurrentGet(&p_part);
else
return 0;
}ProError UserCheckPart()
{return(PRO_TK_NO_ERROR);
}extern "C" int user_initialize()
int menu_id;
return (0);
}extern "C" void user_terminate()
