Could you please let me know whether Axeda platform supports integration with Active Directory?
If yes what kind of support is available?
1. Can I use Active directory to authenticate and authorize user?
2. Can I use the roles from Active directory to grant access to users?
3. Do we have documentation around integration with AD/LDAP?
