Creo 2.0 Tool orientation in Vericut for Mill/turn jobs
ParagVichare
3-Visitor
Hello there,
I have been trying to simulate material removal for mill/turn toolpaths in vericut. The workcell is Mill-turn 5 axis (see attached file).
The tool orientation is right while reviewing toolpath on Creo. Hoever it is chaging in Vericut. Is it just me missing something?
Thanks for the help,
Parag
There was a problem with the coordinate system selection/configuration. Sorted. Thanks
I've got the same problem. How to fix it? What did you change in configuration/selection?
Hi Anna,
Try attached steps. Step 18 is for setting a coordinate system for vericut play. Hope this helps.
Parag
